Old 05-13-2021, 04:51 PM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Turbo View Post
Thanks, Dan.
How is the sidewall stiffness on the CR1? A052 are pretty soft in that respect.
CR-1 seem stiff enough, for me anyway... Seem stiffer vs. A052, but it's been a year and a half and I only ran those tires on the Cayman.
I liked the feedback I got from the CR-1s and they were imo pretty tenacious, I could really drag the car down to the apex.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
jflogerzi (05-16-2021), smg1138 (05-13-2021), Turbo (05-14-2021)
Old 05-17-2021, 10:13 PM   #16
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Just received my 255 CR-1's.
My old 255 Yok A052's are measuring 10" total width mounted on a 9" wide wheel.
The un-mounted 255 CR-1's are measuring 10.25" total width.
I'll report back with mounted width in a couple days.
Breezio is offline   Reply With Quote
The Following 3 Users Say Thank You to Breezio For This Useful Post:
jflogerzi (05-17-2021), SCFD (06-02-2021), Turbo (05-23-2021)
Old 05-17-2021, 10:14 PM   #17
jflogerzi
jflogerzi's Avatar
That's alot of meat. You boosted or NA?
2013 Series 10 FRS #553
Old 05-17-2021, 10:31 PM   #18
Breezio
Breezio's Avatar
NA. Just a header and tune. Car is setup for autocross in STX class, so not much power, all about the cornering grip.
The Following User Says Thank You to Breezio For This Useful Post:
Old 05-19-2021, 08:49 AM   #19
Breezio
Breezio's Avatar
255/40R17 CR-1's on 17x9" +40mm wheel.
Just went out and did a little scrubbing. No issues with rubbing that I didn't already have with my 255 A052s (inside front at full lock)
SCFD (06-02-2021)
Old 05-23-2021, 07:51 PM   #20
Turbo
Drives: FR-S Turbo
Thanks, Breezio!
I've got mine on order now
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
Breezio (05-24-2021)
Old 06-02-2021, 08:45 AM   #21
Breezio
Breezio's Avatar
BTW. First event on the CR-1's went great. Got to try them in wet and dry, performed well both times. Very similar to Yok's.
On the second day, scrubbed in and a good heat cycle, pulled 3rd Pax and 8th Raw (second fastest car not on Hoosiers) out of 60 drivers.
Second event is this weekend. Should be dry and hot. I'm excited.
The Following 2 Users Say Thank You to Breezio For This Useful Post:
Turbo (06-02-2021), ZDan (06-02-2021)
Nankang AR1 TommyW Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 12-17-2019 12:51 PM
Nankang NS-2R 120TW botbs Tracking / Autocross / HPDE / Drifting 1 04-13-2018 05:01 PM
FS: 275/35/18 Nankang NS-20 macaulay7 Canada Classifieds 5 06-30-2017 12:28 AM
Nankang tires FRSure Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-20-2016 08:13 PM
Hankook Ventus Evo V12 K110 - 245/40R17 and 255/40R17 $40 rebate, wholesale Gruppe-s Wheels and Tires 7 10-21-2014 02:11 PM
