Old 05-15-2021, 10:08 PM   #1
Krazyyykevin
Krazyyykevin's Avatar
Drives: 2020 BRZ
Confused on which turbo to get via JDL
Im looking to put a turbo on my stock motor and was confused on which one of these i could use, im looking to get about 280-300hp after its all said and done, Thanks for looking.
Krazyyykevin is offline   Reply With Quote
Old 05-15-2021, 10:17 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Any of them will hit that goal easily.
The advantage to the upgraded 2860rs and above is transient response- meaning how it reacts when you touch the gas pedal initially.
The base turbo is still amazing and perfect for 99% of people
Old 05-16-2021, 12:43 AM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
I would say get the gt2860RS. It's like anything above is basically head room for more power later on. Gt2860RS spools faster and is oil and water cooled iirc whereas the base is just oil cooled.
Sent from my SM-G998U using Tapatalk
Joveen is offline   Reply With Quote
Old 05-16-2021, 11:41 AM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
G>GTX>GT>GTW ...is that correct fellas? I think the G turbos are the newest line. I believe they are the most efficient, and they should provide the most area under the curve, so fast response and decent top end, if I understand what is going on. If the OP has such modest goals then one of these smaller turbos might be good. I think a G25-550 will have the fastest spool, and it will be able to pull all the way to redline. What do you guys think?
http://www.superstreetonline.com/how...ge-big-output/
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
x808drifter (05-16-2021)
Old 05-16-2021, 12:03 PM   #5
Krazyyykevin
Drives: 2020 BRZ
Is it a PITA to setup the water cooling aswell?
Old 05-16-2021, 12:21 PM   #6
Krazyyykevin
Drives: 2020 BRZ
Which turbo would you consider the base? the GT28R right?
Old 05-16-2021, 01:11 PM   #7
Joveen
Joveen's Avatar
Drives: Bone stock
The GT28R is base.
The Following User Says Thank You to Joveen For This Useful Post:
DarkPira7e (05-16-2021)
Old 05-16-2021, 02:27 PM   #8
DarkPira7e
DarkPira7e's Avatar
As @Joveen said, the GT28R is the base model. It's a nice improvement over the previous Precision 4831.
The GT2860RS is unequivocally better in every regard, but I think that extra cost is better invested in supporting mods if your goal is 300whp and under
Old 05-17-2021, 02:21 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
I wonder how the 2860rs would compare to the 25-550 for spool.
Old 05-17-2021, 04:16 PM   #10
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
The G25 should spool faster. If you call JDL they can put the G25 in your kit instead of the options that are in that list.
Mike_ZN6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mike_ZN6 For This Useful Post:
Calum (05-17-2021), x808drifter (05-18-2021)
Old 05-17-2021, 07:09 PM   #11
Joveen
Joveen's Avatar
Drives: Bone stock
I think the G25 is the V3 kit. Maybe g more expensive that the gtx kits and requires the upgraded 700hp intercooler.
Old 05-17-2021, 10:45 PM   #12
Irace86.2.0
From what I have read the GT-550 will spool faster and have more top end. The G25-660 spools as fast or faster than the GTX28, while having the same top end as the GTX35.
I’ve been debating what turbo I would want for the K24. My ideal powerband is more supercharger with something that pulls to redline, but still has low end power and low lag. I feel like the G25-550 might be good, but a little constrictive up top, yet I really don’t want more than 350-400whp for now, so I think the G25-550 will be more than enough.
Old 05-18-2021, 12:49 PM   #13
Krazyyykevin
Drives: 2020 BRZ
I ended up going with this setup
The Following 3 Users Say Thank You to Krazyyykevin For This Useful Post:
DarkPira7e (05-18-2021), Irace86.2.0 (05-18-2021), Joveen (05-18-2021)
Old 05-18-2021, 02:26 PM   #14
Irace86.2.0
Good choice. Best to avoid the disco turbo memes
Hi, Im new and very confused about the car. wolftec Issues | Warranty | Recalls / TSB 29 05-02-2016 09:40 PM
more confused Fred Flintstone Engine, Exhaust, Transmission 8 10-16-2014 11:33 PM
Fog Lights (I'm confused) wehh Cosmetic Modification (Interior/Exterior/Lighting) 4 06-29-2013 09:36 PM
FT-86.....GT-86.....86.....I'm so confused! Hounddub Scion FR-S / Toyota 86 GT86 General Forum 9 11-28-2011 10:52 PM
