Old 05-12-2021, 10:04 AM   #939
Been slowly working on this V1 Rocket Bunny with a 2JZ swap. Just settled on the wheels (Work VS-TX in matte gunmetal). Painted in Honda Phoenix Yellow
Carbon trans tunnel cover with "suede" shifter and ebrake boot + knob, dash mounted gauge pod and Bride Zeta 3 seats. Some JDM red checkered floor mats as well. Deep dish steering wheel with quick release hub.
Heat wrapped the turbo manifold
2JZ even has separate ignition coils
Will post when it's done (in 2025 lol)
And here is a tasty Z tune painted midnight purple III with bronze TE37 cause why not!
Sweet!
StraightOuttaCanadaEh (05-12-2021)
Old 05-12-2021, 09:17 PM   #940
Kaotic Lazagna
Drives: GR Corolla
Picked up some Milliput to try out on filling gaps. Rather messy, but seems better than the Tamiya putty I've used in the pass. Didn't exactly fill the rear bumper gap that well, but better than before.
Also cut up some styrene and made a simple rear spoiler since this kit doesn't come with one.
Old 05-13-2021, 07:00 AM   #941
Wes
People in the hobby that I know actually just use automotive bondo. Cheaper and easier to work with than these expensive hobby putties. Haven't tried myself but seen the results
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Dadhawk (05-13-2021), Kaotic Lazagna (05-13-2021)
Old 05-13-2021, 07:03 AM   #942
Kaotic Lazagna
Drives: GR Corolla
Never thought about that. Just assumed they're much stronger and could possibly eat away at the plastic. The Milliput I got should probably last me for the rest of the kits that I have since only one of them is Aoshima. The rest are Tamiya, so I shouldn't run into any fit and finish issues
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
StraightOuttaCanadaEh (05-13-2021)
Old 05-13-2021, 10:28 AM   #943
Yes you have to be carful with Bondo and some plastics. The Bondo is so aggressive it will indeed eat right through them. I have used glazing and spot putty before but even some of those can be pretty strong.
Pretty much just settled on using the Tamiya stuff over the years since it is designed for use with plastic.
It is funny you hate the Aoshima kits so much. I actually prefer them over the Tamiya ones and they are 1000 times better than the old school American company car kits. Mind you I have only built the one BRZ so far.
Old 05-13-2021, 10:53 AM   #944
turbos86
Drives: 2014 Zenki 37J
Agree with Tcoat with regards to bondo. Putty meant for hobby/plastic use is safer to usefor plastic models kits. Tamiya putties usually gives excellent results, but they have different types of putties for different jobs. Most people make the mistake of just going for their basic white putty in a tube, because it's readily available and cheap, but that's just really only good for filling tiny holds. For filling larger gaps, Tamiya's polyester putty does a better job. And for bodykits or major modifications, they have 2 part epoxy putties.
Aoshima is another whole can of worms. Anything they've newly designed and produced in the last 10 or so years are almost as good at Tamiya. Everything else before that or re-release in a new box (pretending to be a new design) are horrible for fit and finish. The Chaser is, unfortunately, the latter.
turbos86 is offline   Reply With Quote
Old 05-13-2021, 11:02 AM   #945
Wes
yeah you might be right. My circle of modding peeps deal exclusively in 1/18 scale, which is mostly diecast metal, recently with some plastic being introduced. The bumpers, where most of the work is being done, are 99 times out of 100 plastic though, but it might be a different type of plastic from Tamiya kits and such.
Instagram: @gt86ws
Old 05-13-2021, 11:08 AM   #946
It is usually ABS on the diecast. The plastic models are usually polystyrene and much thinner.
Old 05-13-2021, 12:42 PM   #947
Kaotic Lazagna
Drives: GR Corolla
I don't necessarily hate Aoshima. I like how they have modded models from the box. Just the fit and finish hasn't been that good for me. Then again, the Rojam Crown and this Vertex Chaser are either discontinued or re releases. Same for the Rodextyle S15, so I'm already expecting some issues with that one too.
Old 05-13-2021, 12:44 PM   #948
Kaotic Lazagna
Drives: GR Corolla
I actually want the Aoshima Uras R34 Type R, but since it's just been re releases, I'm sure it will have the usual issues.
Old 05-13-2021, 01:40 PM   #949
Yep. If they are releasing old kits they could be from any manufacturers moulds and that can be a real minefield. I always check reviews anymore just to make sure it isn't some 1950s release that is in a shiny new box.
Kaotic Lazagna (05-13-2021), soundman98 (05-13-2021)
Old 05-13-2021, 09:08 PM   #950
turbos86
From what I've heard, the Uras R34 kits are not perfect, but not horrible either.
To be honest, getting things to fit just the way you want, that's just apart of the hobby. Even Tamiya have poor fitting kits, like their R32s.
The Following 2 Users Say Thank You to turbos86 For This Useful Post:
soundman98 (05-13-2021), Tcoat (05-14-2021)
Old 05-13-2021, 09:46 PM   #951
Kaotic Lazagna
Drives: GR Corolla
The Nismo R32 I had no problems with, at least I don't remember any. Haven't built the normal one yet (but I think that's an older tooling than the Nismo). The R33 I had issues with the windows and an odd rear toe in issue.
I don't mind fiddling a little (cuz for all I know, that could be my lack of skills ). Luckily for me, I didn't have a bad wheelbase issue with the Rojam Crown as I've rear some people having non matching chassis to body wheelbases on the regular Crown kit (and the Mine's R34). I didn't appreciate the whole moonroof issue I had with it tho (the main window part not matching up with the optional cut out area).
I think the non "Type R" Uras is a newer tooling, but I can't stand the wide body design of it compared to the "Type R" body.
turbos86 (05-13-2021)
Old 05-13-2021, 09:53 PM   #952
Kaotic Lazagna
Drives: GR Corolla
If anyone is wondering about the differences....
Uras GT-T
Uras Type R
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
spike021 (05-15-2021), StraightOuttaCanadaEh (05-14-2021)
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
