Old 05-11-2021, 01:59 PM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by ZDan View Post
The issue also correlates with not starting session with a full tank. But yeah, the 1st time it happened was only a few laps after the overrev. Engine sounded extremely valve-noisy to me but then I listened to my bud's same-year 86 and it makes the same noises (mostly injector noises I think). We have similar setups, and our acceleration plots fell right on top of each other so my engine is performing normally otherwise.
Still, I was thinking that maybe VVT mechanism(s) might have been damaged and might quit "VVTing" after a few laps, but why would it reliably fail at exactly the same spot on the track every time? @CSG Mike's post about starvation "under the right conditions" is hugely encouraging. Heavily banked 180-degree left-hand NHMS Turn 6, with a little flat table top I use at track-out, while continuing left into Turn 7, on tires that honestly feel faster and more confidence-inspiring here than even 8-cycle Hoosiers I was on last fall, might all add up to "the right conditions".
Bingo.
Fuel pickup is on the driver side.
ZDan (05-11-2021)
Old 05-11-2021, 05:42 PM   #30
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I also get the the loss of power ,with exhaust backfiring, after a double left hander that links(Fish Hook). 6k rpm in 3rd on semis with less than a 1/2 tank or 3/4+ RHD. Must be fuel as I have not revved past 7.6k and it only happens when you nail the section.
Old 05-12-2021, 05:42 AM   #31
54fighting
Drives: 2020 toyota 86
Can someone school me, isn't our rev limiter set well below 9k?
54fighting is offline   Reply With Quote
Old 05-12-2021, 06:13 AM   #32
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
One Scenario.. 4th gear 7.5k rpm and shift into 5th, but you hit 3rd gear by accident. Mechanical over rev! 9k rpm give or take
The Following User Says Thank You to gen3v8 For This Useful Post:
RToyo86 (05-12-2021)
Old 05-12-2021, 10:14 AM   #33
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Not an issue with auto, but with a manual, you have full control over the gears and revs. An extreme example, but the ECU can't stop you from shifting into 1st gear going 60 mph. The rev limiter is only controlled under acceleration, not through gear changes, as this is purely mechanical.
Dzmitry is offline   Reply With Quote
Old 07-22-2021, 05:58 PM   #34
RKTSGN
Drives: BRZZZ
Originally Posted by jflogerzi View Post
ecutek would should show these as well which he has access too.
Would this be able to check our ECU for evidence of an overrev event? And if so, how can we find it? Thanks.
RKTSGN is offline   Reply With Quote
Old 07-22-2021, 06:42 PM   #35
jflogerzi
jflogerzi's Avatar
Only if it created a code but not over rev
2013 Series 10 FRS #553
Old 07-29-2021, 06:24 PM   #36
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Speaking of fuel starvation - whats the fix here? Aftermarket fuel pump?
Hades is offline   Reply With Quote
Old 07-29-2021, 07:13 PM   #37
CSG Mike
CSG Mike's Avatar
Race car? Surge tank.
Old 07-30-2021, 06:42 PM   #38
Hades
Hades's Avatar
No not race car, more dual purpose track/street car. I guess there's not really a solution for that scenario?
Old 07-30-2021, 07:50 PM   #39
CSG Mike
CSG Mike's Avatar
Just run a full tank.
Old 07-30-2021, 11:50 PM   #40
Hades
Hades's Avatar
Is this adequate with F/I + R-comps though? Sounds like F/I for a street car basically means no racing slicks/high Gs otherwise.
EDIT: Sorry to hijack thread lol
Old 07-31-2021, 12:29 AM   #41
CSG Mike
CSG Mike's Avatar
Depends on the rest of the car and what exactly you want to do, but probably yes.
Possible overrev on the track; does ECU store max lifetime RPM reached? SmoothIsSlow Engine, Exhaust, Transmission 21 07-22-2021 06:04 PM
Need help about the mechanical coverage! hoangjm Scion FR-S / Toyota 86 GT86 General Forum 29 04-11-2019 02:51 AM
frs oversteer in brz mechanical? swpbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-18-2014 09:48 PM
Overall mechanical satisfaction? Tman08 Issues | Warranty | Recalls / TSB 15 08-26-2013 05:28 PM
