Old 05-09-2021, 12:11 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Mechanical overrev, 9k
Got 3rd instead of 5th at the track, saw 9k before clutching. Seemed to run ok after that for a few laps but then lost a ton of power. But only temporarily. Power cam back but dropped a lot again, as if ECU going into a limp mode. Sounds like some lifter noise at hot idle in pits.
Pondering:
Do I run 3lap TT? Just drive home 150 miles away, or have it flat towed to shop?
Old 05-09-2021, 12:48 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Just listened to friend's same year 86 sounds same lifter noise so mildly encouraged...
Lost power on extended hard left and power loss felt similar to fuel starvation I've had before, but have just under 3/4 tank so...
Old 05-09-2021, 01:02 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've zinged mine about that hard before and it was okay. If it kissed a valve you'd know it, I don't see a lifter being an issue, they move almost nil.
Old 05-09-2021, 01:06 PM   #4
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I loose power after long hard left! The car gets a massive pop tune sound. I`m not sure if it`s a traction control shutdown or fueling issue
Old 05-09-2021, 01:09 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This helps a LOT.
https://www.verus-engineering.com/sh...e=2&category=1
gen3v8 (05-09-2021)
Old 05-09-2021, 02:42 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
If everything sounds normal I wouldn't worry about it. If you broke something you'd know.
TommyW is offline   Reply With Quote
Old 05-09-2021, 03:47 PM   #7
Cali Girl
Cali Girl's Avatar
Drives: 86
Thank you
Cali Girl is offline   Reply With Quote
Old 05-09-2021, 03:59 PM   #8
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Rocker retainer may have come off which is typical on an over rev.
Some companies sell a revised rocker/retainer this not susceptible to this.
https://denstoj.com.au/products/fa20...r-retainer-kit
PRO86 | WTCC | STL
Old 05-09-2021, 07:10 PM   #9
jflogerzi
jflogerzi's Avatar
I did a small money shift in the car this weekend in the AM. Car shrugged it off and I even managed to match my best AM time at 2:30 in the afternoon in 85-90f weather. Safe to say power seemed fine
If your going to do the fuel door flapper mod might as well replace the fuel pump while your in there.
As others said of she sounds fine then I would not worry.
2013 Series 10 FRS #553
Old 05-09-2021, 10:12 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
I don't think it's fuel starvation. I went ahead and fuelled up and ran my 3-lap time trial, no prob. I did slower times than 1st practice this AM by 1 second but mainly because I was too tentative and worried, my fastest lap I actually didn't do the 4-5 shift on the front straight, which cost me 0.3 sec. Car seemed to behave normally during TT. I got 2nd in TT to a Hoosier-shod Miata (dedicated track car) by less than a tenth, DOH!
In open-track after TT, the power-loss coming out of turn 6 (NHMS, long heavily cambered left hander) happened again, with a nearly full tank. Hmmm...
Was able to capture it in log files via ECUtek (which I'm a total newb to), gonna send .csv log files to tuner to get an idea what's happenin. Seems like VVT might not be VVTing, doesn't sound like anything BAD is happening, it just goes limp.
TL/DR, it's still happenin and it aint' fuel starvation (I don't think)
Ultramaroon (05-09-2021)
Old 05-09-2021, 10:22 PM   #11
jflogerzi
jflogerzi's Avatar
So it throws a code and goes into limp? If you were in limp you would be stuck below 4000 rpm
Old 05-09-2021, 10:43 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
No codes thrown, just loses power, then kinda recovers after a bit. *Almost* as if it were fuel starvation.
Old 05-09-2021, 10:51 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Weird. Is it easy to replicate? I would think if it was a VVT issue it would give you a code P00XX code for camshaft position correlation or response.
Old 05-09-2021, 10:58 PM   #14
jflogerzi
jflogerzi's Avatar
Just cause you have a full tank you can still get fuel starvation
@CSG Mike
Possible overrev on the track; does ECU store max lifetime RPM reached? SmoothIsSlow Engine, Exhaust, Transmission 21 07-22-2021 07:04 PM
Need help about the mechanical coverage! hoangjm Scion FR-S / Toyota 86 GT86 General Forum 29 04-11-2019 03:51 AM
frs oversteer in brz mechanical? swpbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-18-2014 10:48 PM
Overall mechanical satisfaction? Tman08 Issues | Warranty | Recalls / TSB 15 08-26-2013 06:28 PM
