Drives: 2014 Toyota 86 GTS
Estimating exhaust volume (dB)
I admit this is a bit silly, but is there anyway to estimate how loud an exhaust will be (eg mathematically) to meet track noise limit requirements? I've tried using sites that estimate dB at a distance but it doesnt seem right. For example:
According to FR-Sport (https://bit.ly/2PnkruJ), they measured Tomei 60r (no other mods) at 107db @10'. Therefore according to this physics site (https://bit.ly/2PT5sZ0) it would be 92.1 db @ 55 feet, which is apparently just over the noise limit at laguna. Then again someone with a Buddy Club Spec II measured 95.8db @ 100 feet by a autocross marshall. which would mean it would be 115db @ 10' LOL Does this make sense to you guys? |
#2 |
TRACKBREAD
Yes it makes total sense. Both those exhausts are loud as duck, and Laguna Seca has fairly strict limits compared to other tracks.
As for estimating it, not really. Sound pressure will not stack predictably with other mods, and it can come down to even which exhaust hangers and how many you're using. Measuring is the only real way. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | ls1ac (04-03-2021) |
#3 |
Further, it does not act as a point source. So radiation pattern is not even and equal.
| The Following User Says Thank You to ls1ac For This Useful Post: | Yoshoobaroo (04-03-2021) |
#4 |
Yep, when your SO yells that "your exhaust is so loud, I can't even hear the radio" - that is too loud.
| The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (04-04-2021) |
#5 |
Thanks everyone, I knew the estimation calculation results were too good to be true haha. Guess i'll focus on other areas of the car for weight then
#6 |
Drives: 2013 frs red
The look on your neighbors face is as good as any db meter.
#7 | |
2013 Series 10 FRS #553
#8 |
you can get a silencer for the t60r and t80r. just put in the silencer if you are on a track with strict limits. not ideal for power but butter than being sent home.
#9 | |
Drives: '13 BRZ
| The Following User Says Thank You to BRZoomTX For This Useful Post: | humfrz (05-07-2021) |
#10 |
Drives: '13 Whiteout
If you had a car with more power you could lift at the tower but with an 86 you’ll be crawling up to T6
#11 |
| FT-86 Speedfactory V1 Exhaust (Resonated) Volume? | Sh1FTy | Engine, Exhaust, Transmission | 1 | 01-29-2018 11:06 AM |
| Exhaust note nearly perfect... But can you help me bring down the volume? | ajcarson11 | Engine, Exhaust, Transmission | 60 | 06-07-2016 04:28 PM |
| Front pipe variations and exhaust volume | Vmax911 | Engine, Exhaust, Transmission | 9 | 03-05-2014 05:04 PM |
| Exhaust volume | twag4 | Engine, Exhaust, Transmission | 17 | 09-24-2013 05:12 PM |
| Cold Start Exhaust Volume | SilentMike | Engine, Exhaust, Transmission | 15 | 04-04-2013 11:49 AM |
