Drives: 2016 TOYOTA 86
Hi
| The Following User Says Thank You to ohno For This Useful Post: | humfrz (05-07-2021) |
#2 | |
![]() What do you mean by "downshift on 2nd last gear is rough"? What does the "pulley type noise" sound like? Those codes are over my pay grade, however, I will try to summon up ol @steve99 for you. |
#3 | |
Good luck. |
#4 |
Drives: FT86
http://www.ft86club.com/forums/attac...1&d=1378232133
check tsb above once to get an engine dtc code it often puts transmission in limp mode as well and can cause rough shifting also if your car is 2012 auto it should be on ZA1JA01I ecu firmware not earlier ZA1J700I or ZA1JA00I assumiing its auto the rattle noise qt idle is likely the vaccuum pump for brake booster its very comon issue on auto cars |
| The Following User Says Thank You to steve99 For This Useful Post: | humfrz (05-10-2021) |
#5 | |
Drives: FT86
It could be that a bit of wear over the years has just put it over the tolerance for the error detection. Get the firmware update for ecu and check the cam sensor as per tsb will very likely fix issue |
| 3rd brake light rattle? | Tysoncrosby21 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 04-12-2017 03:36 PM |
| Third brake light causing rattle | BIL90 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 11-28-2016 11:27 AM |
| 3rd brake light rattle easy fix | xITSxTHExPOPEx | Electronics | Audio | NAV | Infotainment | 2 | 12-14-2014 06:14 PM |
| Rattle from break light behind rear windshield! | Danny | Issues | Warranty | Recalls / TSB | 2 | 06-30-2014 11:26 PM |
| Subwoofer 3rd Brake Light Rattle | mmieszanek | Electronics | Audio | NAV | Infotainment | 5 | 05-01-2013 12:21 PM |
