Old 04-10-2021, 02:28 AM   #29
jflogerzi
jflogerzi's Avatar
Originally Posted by Ernest72 View Post
If you are tracking some of those panels could lead to heat building up in your rear diff because it does not get any air, do a search on it. On the street it’s not likely an issue,
For the street it's useless... Got any links? Curious more than anything else..
2013 Series 10 FRS #553
Old 04-10-2021, 10:35 AM   #30
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by 86TOYO2k17 View Post
They are same diameter. Just different width.
Different width is the problem. Makes the car an understeery mess. Not sure if it contributes to feeling light at speed, but I havent driven a factory alignment in so long (let alone on the highway)...
The Following User Says Thank You to cjd For This Useful Post:
Capt Spaulding (05-21-2021)
Old 04-10-2021, 11:14 AM   #31
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I had almost the same setup when I bought my car.
While I wouldn't have called it floaty, it was definitely understeery AF compared to now with the stock tire sizes on OEM wheels.
Find some used OEMs for cheap and lose the boat anchors.
Old 04-10-2021, 12:15 PM   #32
Ernest72
Know
Do a search, it was on this forum. There was a discussion that a shop had higher temps in the diff with all the aero. I don’t think it’s deal closer, just something to think about with changing fluids more often and such.
The Following User Says Thank You to Ernest72 For This Useful Post:
jflogerzi (04-10-2021)
Old 04-10-2021, 12:38 PM   #33
jflogerzi
jflogerzi's Avatar
Originally Posted by Pat View Post
High speed stability can be achieved with exactly zero of those modifications. That said, I would love to drive a car with all of those modifications to compare it directly to one without. I'm skeptical I would feel any difference.
You should pick up a bit of mpg and should be able to carry some more speed on the track due to less drag and the car being more stable
Old 04-10-2021, 01:16 PM   #34
Pat
Pat's Avatar
Drives: 2023 BRZ
In theory I totally agree. In practice I'm skeptical I could feel much.
Old 04-10-2021, 06:44 PM   #35
PulsarBeeerz
Drives: JRSC BRZ SOLD
You can't always feel what the stop watch saw.
PulsarBeeerz is offline   Reply With Quote
Old 04-10-2021, 06:48 PM   #36
86TOYO2k17
Drives: 2017 toyota 86
Width doesn’t matter for his issue.
I was also staggered 225/255 zero issue.
Old 04-10-2021, 06:56 PM   #37
86TOYO2k17
At 100mph+ it’s beyond noticeable the difference.
Take a car with zero aero,
Add only a real functional front splitter. And prepare to hate driving at 100mph+.
Then add a diffuser to the above to rebalance it and prepare to love driving at 100mph+ the feeing is night and day.
From a drag reduction stand point you won’t really feel that. IIRC the drag reduction at 100mph for everything combined was the equivalent to about 10whp or 2.5whp at 50mph, I calculated it out once. Which i guess adds up but 10whp isn’t that noticeable.
From a downforce / reducing lift stand point though, It’s huge. Below 80 you dont really feel it, at 80 you start to feel it by 100 it’s very noticeable and by 120 you couldn’t imagine driving without it.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
vintagemxer (05-05-2021)
Old 04-10-2021, 10:07 PM   #38
Pat
Pat's Avatar
Drives: 2023 BRZ
Huh. Interesting. I'd love to experience that first hand.
Old 05-05-2021, 04:09 PM   #39
bfeeney
Drives: 2015 Scion FR-S
Thanks everyone for the comments. I got an alignment, it didn't do much. I tracked down the wheels that came on the car, they're Avid.1 SL01's 8.5" & 9.5". Before the end of Fall I'll get two of the 8.5" wheels and mount either 225's or 235's all the way around. I really haven't put too much thought in the width yet, I'm open to suggestions for a spirited DD. I think a good chunk of my stability problem is the OEM suspension that has 114k on it. I did see wet spots on the shock boots indicating a leak. I'm going to get KYB GR2's and Tein H Tech springs very soon because I notice a descent amount of bounce when I drive. Does anyone know if a ~.6" rear drop will mandate adjustable toe bars? I'm planning on getting a camber/toe kit, but I don't have all the cash to do it all at once.
bfeeney is offline   Reply With Quote
Old 05-05-2021, 05:43 PM   #40
RayRay88
Drives: 2017 86 860 Special Edition
Your stock adjustment for toe will get you back in spec, you'll need adjustable rear lower control arms if you want to adjust the camber. Not really necessary for such a mild drop if you're fine with whatever camber in the rear comes naturally. I would advise against KYB's, you could get Koni's or better yet Bilsteins. They are miles more advanced than KYB GR2's. Look into Eibach or Racecomp springs.
If you're on a budget I suggest looking for lightly used 17+ dampers and springs.
RayRay88 is offline   Reply With Quote
Old 05-05-2021, 07:01 PM   #41
bfeeney
I didn't know the OEM had adjustment, that's good. I like the KYB's for daily drivers, I've used them on all my shock/strut replacements. I know the Koni and Bilstein are much better, but they're also overkill for me. I consider the KYB's to be the best of the OEM+ struts but not something I would take to a track.
The Eibach springs lower the car more than I want, and they're $100 more than either Tein set.
Old 05-05-2021, 09:02 PM   #42
RayRay88
Understood. Just keep in mind the OEM parts are very competent, and while KYB may have been an upgrade for Hondas it may certainly be a downgrade for a sports car like the twins.
Also compromising for comfort and daily driving, while overlooking simple upgrades like high quality dampers and then asking for high speed stability/aerodynamics is very much conflicting. Your vehicle is a system and a sum of all parts. It will only be as good as its weakest mechanical part.
Fiberglass underbody panel upgrade? YamahaR86 Cosmetic Modification (Interior/Exterior/Lighting) 10 01-14-2020 11:04 AM
"duct" panel near underbody is loose and rattling Spacemane969 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-01-2020 02:12 PM
WTB underbody panel EvolutionRevolution Want-To-Buy Requests 0 10-23-2019 08:49 PM
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 01:10 AM
Window tint/ Air 80 Effectiveness Da Brz Cosmetic Modification (Interior/Exterior/Lighting) 0 07-11-2016 10:15 AM
