Old 04-14-2021, 01:26 PM   #15
ninjan00dles
Drives: 2015 FRS
Originally Posted by TommyW View Post
I used an IAG shortblock and my very competent engine builder used one so guessing there are no issues ay least with the FA20 version. I looked at it before install and it looked like a very solid unit compared to stock
Hey Tommy, do you have a baffled oil pan as well?
ninjan00dles is offline   Reply With Quote
Old 04-14-2021, 01:32 PM   #16
Joveen
Joveen's Avatar
Drives: Bone stock
I heard that it does pair up well with the maperformance pan/ full blown pan with baffle.
Sent from my SM-G998U using Tapatalk
Joveen is offline   Reply With Quote
Old 04-14-2021, 01:39 PM   #17
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Here is mine, too long, bottomed out on oil pan. After months of trying to get a replacement I told them to just forget it. I initially just asked for the measurement on how long it should have been and I was going to cut it myself. They insisted of me sending it in, I should have said forget it and just cut it the same length as the stock pickup. Basically paid 130 bucks to write a "do not recommend" review on their FB page.
i just measured mine with some calipers on a table and its 3.455" tall not sure what oem is. also i did get a bluemoon baffle because id like my engine to continue to get oil
Old 04-14-2021, 01:55 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't have a stock one to measure right now. I haven't tore apart my spare motor yet.
100% recommend the baffle.
Old 04-14-2021, 02:09 PM   #19
Breadman
Breadman's Avatar
the oem one i pulled out of my donor is 3.61" so slightly taller
The Following User Says Thank You to Breadman For This Useful Post:
NoHaveMSG (04-14-2021)
Old 04-14-2021, 03:42 PM   #20
TommyW
TommyW's Avatar
Drives: '13 Whiteout
No
TommyW is offline   Reply With Quote
Old 04-15-2021, 12:24 AM   #21
Most people I have heard got one had no issues. I don't think I would worry. I am not even that annoyed it was messed up, it was the whole ordeal of them getting me a replacement I just said forget it.
That's one epic QC fail. Thanks for calling them out on it.
NoHaveMSG (04-15-2021)
Old 04-15-2021, 04:30 AM   #22
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
I second this. Thank you!
For such a critical part, not to have strict 100% control via a measuring jig for example (which is based on the dimensions of the OE part - length, angle,...) is beyond me
This pick-up tube was also on my radar.
Perhaps I'll just make one myself...
Boccaccio is offline   Reply With Quote
Old 04-15-2021, 07:26 AM   #23
Breadman
Breadman's Avatar
welp i had no idea this was an issue, i guess this is what hes talking about
Old 04-15-2021, 10:53 AM   #24
Code Monkey
Drives: Subaru BRZ
I have had mine for over 5,000 miles and multiple track days, no issues so far...
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
alphasaur (04-20-2021)
Old 05-01-2021, 04:59 PM   #25
ninjan00dles
Drives: 2015 FRS
Just a datapoint. I just installed a KillerB pickup with a bluemoon baffle and everything fit fine. The pickup does come with a new set of socket head cap screws which I believe are too long though. It felt like they were bottoming out so I used the original OEM fasteners instead
The Following 2 Users Say Thank You to ninjan00dles For This Useful Post:
jrhudson (05-02-2021), NoHaveMSG (05-01-2021)
Old 08-03-2021, 05:13 PM   #26
jrhudson
Drives: 2016 scion frs
Can confirm bluemoon baffle and killer b oil pickup should work together with the oil pan. I mocked it up and its fine.
Also the provided allen bolts don’t bottom out. The bolt whole is about 19mm deep and the allen bolt is about 16mm. I even hand threaded the bolts in without any resistant.
jrhudson is offline   Reply With Quote
The Following User Says Thank You to jrhudson For This Useful Post:
DarkSunrise (08-03-2021)
Old 08-03-2021, 07:12 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Dry fit your oil pan over the top of it. That was my issue, pickup hit the oil pan.
Old 08-03-2021, 07:42 PM   #28
jrhudson
Yea thats what i did. It fits perfectly.
This is the end result. This pic is of when i applied the threebond on it. Sorry it isnt the best pic.
NoHaveMSG (08-03-2021)
OFT V1 Unmarried and KillerB Oil Pickup Griever423 Engine, Exhaust, Bolt-Ons 7 04-09-2021 10:08 AM
Gap Between Oil Pickup & Oil Pan? Bonburner Engine, Exhaust, Transmission 2 10-17-2018 05:02 AM
FS: KillerB Delrin Shift Knob (Black) skylinekin Interior Parts (Incl. Lighting) 3 07-12-2017 07:09 PM
86 pickup DavidBob Scion FR-S / Toyota 86 GT86 General Forum 45 01-19-2015 01:10 AM
Wanted: BRZ in GTA with immediate pickup smartAdmin CANADA 0 07-10-2012 01:42 PM
