Drives: 2013 WRB BRZ Limited
Stock toe arms are shot. Good OEM replacement?
The rubber around my rear toe arms are falling apart. I am looking to replace them but honestly don't know much about them. The alignment shop I took them too just said get some cheap ones from rock auto. I'm lowered only a little on RCE yellow springs. Can someone recommend something for me from Rock Auto?
I don't think adjustable ones are necessary, also would bump me out of STX in autox if i'm not mistaken. |
#2 | |
MOOG is a good brand. adjustable ones do not bump you out of STX, as long as they stay rubber bushings.
| The Following User Says Thank You to BigTuna For This Useful Post: | oldlostcory (04-29-2021) |
#3 | |
Drives: '13 FRS - STX
Edit; looks like Rockauto only has adjustable units, I'd hit up a dealership if you're really concerned about being STX legal otherwise anything on Rockauto should be acceptable. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | BigTuna (04-29-2021), oldlostcory (04-29-2021) |
#4 | |
#5 | |
Drives: 2017 86 860 Special Edition
| The Following User Says Thank You to RayRay88 For This Useful Post: | oldlostcory (04-29-2021) |
#6 |
Drives: 17 Asphalt 86
What does the dealer want for OEM?
I'd call both Subaru and Toyota and compare. I Often find Toyota cheaper for most things. |
#7 |
#8 | |
#9 |
#10 |
Drives: 2015 Scion FRS
The Moog toe arms are actually SPC. They are branded SPC and everything. You can order them from Rock Auto.
| Blox lower control arms - good enough? | 86league | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-28-2019 02:23 PM |
| Need to buy: stock rear lower control arms/toe arms and intake elbow | CoolHandMoss | Want-To-Buy Requests | 6 | 07-12-2018 08:44 AM |
| Stock suspension shot, looking to replace with Bilstein B8/RCE Tarmac. | rapidcars | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-27-2018 01:56 PM |
| FS: oem toe arms and oem lca. good condition. located in california | jay92 | Brakes, Suspension, Chassis | 0 | 10-16-2016 11:46 PM |
| Good DIY for speaker replacement. | ST185RC | Electronics | Audio | NAV | Infotainment | 5 | 02-10-2013 02:47 PM |
