Old 04-28-2021, 04:33 PM   #1
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
Stock toe arms are shot. Good OEM replacement?
The rubber around my rear toe arms are falling apart. I am looking to replace them but honestly don't know much about them. The alignment shop I took them too just said get some cheap ones from rock auto. I'm lowered only a little on RCE yellow springs. Can someone recommend something for me from Rock Auto?
I don't think adjustable ones are necessary, also would bump me out of STX in autox if i'm not mistaken.
oldlostcory is offline   Reply With Quote
Old 04-28-2021, 05:05 PM   #2
BigTuna
BigTuna's Avatar
MOOG is a good brand. adjustable ones do not bump you out of STX, as long as they stay rubber bushings.
14.8.B
Suspension bushings may be replaced with bushings of any materials
(except metal) as long as they fit in the original location. Offset bushings
may be used. In a replacement bushing, the amount of metal relative to
the amount of non-metallic material may not be increased. This does
not authorize a change in type of bushing (e.g., ball and socket replacing a cylindrical bushing) or use of a bushing with an angled hole whose
direction differs from that of the original bushing. If the standard bushing accommodated multi-axis motion via compliance of the component
material(s), the replacement bushing may not be changed to accommodate such motion via a change in bushing type, for example to a spherical bearing or similar component involving internal moving parts. Pins
or keys may be used to prevent the rotation of alternate bushings but
may serve no other purpose than that of retaining the bushing in the
desired position.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
oldlostcory (04-29-2021)
Old 04-28-2021, 06:07 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You're only allowed to change one lateral link of a multi-link suspension per a letter written last year or the year before, better to change the one that isn't factory adjustable and use the OE adjustable arm then be stuck with the OE non-adjustable arm.
Edit; looks like Rockauto only has adjustable units, I'd hit up a dealership if you're really concerned about being STX legal otherwise anything on Rockauto should be acceptable.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
BigTuna (04-29-2021), oldlostcory (04-29-2021)
Old 04-29-2021, 09:24 AM   #4
oldlostcory
Is there any reason I can't buy something like this one? Is it not an OEM equivalent? They aren't adjustable like the other ones, but look identical to the OEM ones.
Old 04-29-2021, 10:01 AM   #5
RayRay88
Drives: 2017 86 860 Special Edition
Can't help with your question, but I'll chime in with avoid Mevotech like the plague. Terrible QC and parts. This is first hand experience with their stuff and from working there. Some of their premium stuff is ok but varies from part to part.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
Old 04-29-2021, 10:21 AM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
What does the dealer want for OEM?
I'd call both Subaru and Toyota and compare. I Often find Toyota cheaper for most things.
Old 04-29-2021, 10:43 AM   #7
oldlostcory
Toyota and Subaru wanted $132 each and $148 each for OEM ones.
Old 04-29-2021, 10:57 AM   #8
strat61caster
Yeah that looks fine, my bad I must have missed that one.
ineedyourdiddly
Old 04-29-2021, 11:07 AM   #9
RToyo86
RToyo86's Avatar
Mevotech has a lifetime warranty which is a plus. Just not sure how it would be to deal with rockauto in a warranty situation should it come up.
Old 05-01-2021, 03:02 AM   #10
andrew4554
Drives: 2015 Scion FRS
The Moog toe arms are actually SPC. They are branded SPC and everything. You can order them from Rock Auto.
andrew4554 is offline   Reply With Quote
Blox lower control arms - good enough? 86league Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-28-2019 02:23 PM
Need to buy: stock rear lower control arms/toe arms and intake elbow CoolHandMoss Want-To-Buy Requests 6 07-12-2018 08:44 AM
Stock suspension shot, looking to replace with Bilstein B8/RCE Tarmac. rapidcars Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-27-2018 01:56 PM
FS: oem toe arms and oem lca. good condition. located in california jay92 Brakes, Suspension, Chassis 0 10-16-2016 11:46 PM
Good DIY for speaker replacement. ST185RC Electronics | Audio | NAV | Infotainment 5 02-10-2013 02:47 PM
