#85 |
BAE
Drives: Asphalt FRS
True, the CAL ID is locked for the ECU right? I have a 2013 ECU with a 2016 motor w/ a 2016 E85 flex tune loaded. Its been awhile since i loaded the tune so ima go back and double check the cal-id.
#86 |
Got a notice to smog my car for re-registration and looks like i got selected to go to a STAR station. I think these are more tightly controlled/inspected smog stations and based on basic research i think certain models of cars are selected to go to a STAR station because they are more likely to fail or more likely to have some funny business that the state doesn't trust all smog techs to look for.
what they don't know of course is that i can put headers on right after i pass. then it looks like 2 years of no torque dip lol |
#87 | |
Certified Wumbologist
Drives: 2015 Scion FR-S
#88 | |
2013 Series 10 FRS #553
#89 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Why would flex fuel fail you? Isn’t E85 closer to carbon neutral when compared to petrol?
#90 | |
#91 | |
#92 |
Drives: Scion FR-S Series 10 #2462
Just passed my smog, pretty much stock other than some Crawford Power Blocks. I had a catch can, which I de-installed before the test. No issues.
#93 | |
![]() Sent from my GM1915 using Tapatalk
#94 |
6/22/12-2/6/24
catch cans are a smog issue?
#95 |
Depends on the shop.
#96 |
Famous Potatoes
Drives: '15 ultramarine
#97 |
BAE
Drives: Asphalt FRS
#98 |
Senior gif poster
Drives: 2013 Asphalt FRS
I just got the old FRS smogged today for the first time, everything went smoothtly. Car passed, no rollers, no lift. Just popped in the OBDii and blipped the throttle a few times, visual inspection and I was done.
I knew there was nothing on the car that would fail smog, but you never know. I was concerned I might have to show my J02 recall certificate (which I have) however he didn't need to see that. The guy said my catback was totally fine. This was in Orange county (south) Ca. |
| Smog check for out of state people? | goshem | Southern California | 4 | 09-25-2015 06:20 PM |
| CA Smog Check?? | JG | Southern California | 22 | 06-08-2015 11:05 AM |
| WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho | continuecrushing | Southern California | 13 | 01-26-2015 11:19 PM |
| Need advice on passing smog in California | rmak321 | Northern California | 7 | 07-12-2014 12:52 AM |
| Smog check and visual inspection help | Corradooo | Northern California | 24 | 05-19-2014 11:57 PM |
