Old 02-17-2021, 10:29 AM   #225
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Pressed new ARP Studs into brand new SKF wheel bearings (all 4)...now just need the motivation to actually install them on the car...LOL
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 02-22-2021, 09:11 PM   #226
Opie
Opie's Avatar
Install a Tomei Expreme Ti Type-80 Catback Exhaust, gawd this thing is loud....but awesome...and installed a Kartboy Transmission Mount Insert. Probably start on the wheel bearings tomorrow...
Old 02-23-2021, 10:10 PM   #227
Opie
Opie's Avatar
Got the front SKF Bearings w/ARP's installed tonight, adjusted ride height and removed some more unnecessary weight, down to around 2,640lbs now...start on rear bearings tomorrow.
Old 02-25-2021, 11:54 AM   #228
Opie
Opie's Avatar
LOL, got 1 of the Rear SKF Bearings w/ARP's installed last night. Did I mention I hate drum parking brakes? Working on the other one after lunch.
The Following 2 Users Say Thank You to Opie For This Useful Post:
RToyo86 (04-21-2021), Ultramaroon (02-26-2021)
Old 02-25-2021, 06:14 PM   #229
Opie
Opie's Avatar
Ok, cliff notes of the past week:
Removed Invidia Q300 exhaust, replaced with Tomei Expreme Ti Type-80 Catback Exhaust, installed a Kartboy Transmission Mount Insert, removed OEM rear muffler heat shield (weight savings 1oz ), raised front coils 15mm, found stripped coil perch set screw...repaired, raised rear 20mm with LCA adjustment and coils, Installed 4 new SKF wheel bearings, pressed in ARP extended studs before they were installed.
Going to watch the 12-Hour at Sebring on March 19-20 then going to run the car at Sebring March 27-28, April 10-11 & April 17-18...probably should order another set of tires....
NoHaveMSG (02-25-2021), Racecomp Engineering (02-26-2021)
Old 02-25-2021, 06:23 PM   #230
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The rears are such a bitch. I will probably redo mine this year and am dreading it.
Old 02-26-2021, 08:21 AM   #231
Opie
Opie's Avatar
Pretty sure the next time I do them....I'm going to delete the parking brakes. Not like a race car needs a parking brake...
The Following User Says Thank You to Opie For This Useful Post:
Old 03-10-2021, 04:23 PM   #232
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Can confirm.. I thought my Invidia Ti exhaust was somewhat loud but that type-80 is insanely loud.
No sound limit days at Laguna only for you.. if you ever go... (and it's not really worth it).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Opie (03-10-2021)
Old 04-19-2021, 05:54 PM   #233
Opie
Opie's Avatar
Had a fun weekend at Sebring running Round 3 of the SouthEast86Cup. Ran some great laps and managed to do a 2:35:36 but was bested by Dave-Ror with a 2:34:80, I'll try and get some video up soon.
villainous_frx (04-20-2021)
Old 04-20-2021, 11:05 PM   #234
Opie
Opie's Avatar
Here is my Modified Class 2nd Place lap:
The Following 5 Users Say Thank You to Opie For This Useful Post:
jflogerzi (04-26-2021), Lonewolf (04-22-2021), ripper (12-15-2021), RToyo86 (04-21-2021), Wally86 (04-21-2021)
Old 04-26-2021, 10:42 PM   #235
jflogerzi
jflogerzi's Avatar
Looks like a fun high speed track. Early on in the lap you got really close to the wall..
2013 Series 10 FRS #553
Old 04-27-2021, 03:52 PM   #236
Opie
Opie's Avatar
Just looks close I'm using all the track
** has spare door if things go wrong....
jflogerzi (05-08-2021)
Old 04-27-2021, 09:10 PM   #237
Petah78
Drives: 2022 BRZ sport-tech
Impressive that you have tracked this thing for 4+ years already. How many track miles? Any mechanical/catastrophic failures?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 05-03-2021, 05:05 PM   #238
Opie
Opie's Avatar
It has close to 10k track miles, 34k total. Still on original block, transmission, clutch & rear diff.
Only mechanical failures was a left Rear axle.
Early on I had repeated Cyl #3 coil pack issues but since I upgraded the engine harness & coil packs to the 2015 style, no more issues.
On my 6th or 7th set of tires, 2nd set of front rotors, 4th set of front pads, 2nd set of rear pads and just replaced all 4 wheel bearings.
Car just loves it!
The Following 3 Users Say Thank You to Opie For This Useful Post:
Petah78 (05-03-2021), ripper (12-15-2021), Wally86 (05-10-2021)
NORGP GT86 just for Track Rebuild Panamaniac Member's Car Journals 25 12-06-2019 08:41 AM
History of my GS-R.. and rebuild.. my now-current track car. Dave-ROR Other Vehicles & General Automotive Discussions 35 12-12-2013 08:02 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
FS: 2013 Totalled BRZ FS (~5,000 miles) eklipz98 Northern California 45 02-03-2013 01:16 AM
