Old 08-14-2020, 11:32 PM   #15
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Guys, (and gals?) I just did a lengthy and informative write up that addresses what sounds to be the situations you are having.
It can be found here:
https://www.ft86club.com/forums/showthread.php?t=141915
FR-S2GT86 is offline   Reply With Quote
Old 04-27-2021, 09:42 AM   #16
Drafter
Drives: 2017 Brz
Door speakers not working after new head unit install
Thanks so much for your write up. I had the same issue with the front door speakers not working. The rear amp is not getting any power. With your write up and a few others I was able to identify the brown wire coming from the car that had no mate in the Crutchfield supplied Crux adapter. I cut the brown wire from Pin 9 and connected it to the REM out wire from the new head unit, along with the antenna amp wire. Now the speakers work and I have radio reception.
Drafter is offline   Reply With Quote
Old 04-27-2021, 11:29 AM   #17
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Not sure if your comment was aimed at me or not, but if it was thanks.
I just spent a few minutes editing that write up so you don't have to scroll all the way down to see the diagrams that I mentioned when describing the different harnesses, plugs and adapters. Just makes it easier (less difficult?) to read.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
Old 04-27-2021, 04:23 PM   #18
Drafter
Drives: 2017 Brz
Absolutely! Both you and the OP. Putting your posts together in my mind got me on the right track and now I have sound!
Now to deaden the other sounds. (Without adding much weight. This thing is too fun to ruin it with extra mass.). I have a 2017 that I bought three weeks ago.
door speakers not working number1Tango Electronics | Audio | NAV | Infotainment 23 04-03-2022 07:03 PM
MD: BRZ Head Unit + Speakers itsfun Audio/Visual, Electronics, Infotainment, NAV 2 04-06-2013 09:03 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 04:59 PM
New head unit/speakers Dkittrell Electronics | Audio | NAV | Infotainment 5 06-27-2012 03:01 PM
