Drives: '23 BRZ
Good shop near RI/Boston/Eastern CT to install header?
Been putting it off, now reality says there's no way I'ma install my ACE350 header between now and track days on May 8/9.
Looking for recommendations for a good preferably Subaru- even more preferably FT86-centric shop near RI, SEMass, eastern Connecticut. TIA! |
#3 |
Drives: '23 BRZ
#4 |
That Guy
Drives: 2013 asphalt FRS MT
Realistically this isn't something that should require a specialist. It's just a header on a car that is put together like Lego.
Take off the heat shield Remove O2 sensors Remove factory manifold Disconnect passenger side engine mount Remove over pipe Install new over pipe Install header Reconnect engine mount Install O2 sensors The only tricky part is going to be installing the tune. You'll be able to limp it home on the factory tune and then update the tune yourself in a few minutes. Unless you don't even have time for that I'd just take it to any exhaust shop. Sent from my Pixel 4a (5G) using Tapatalk |
| The Following User Says Thank You to Calum For This Useful Post: | ZDan (04-25-2021) |
#5 | |
Drives: SWP BRZ
it's all about choice. take a day off or dont hang out with friends for that weekend. haha Joke you can just go to local shop and install. this is not rocket science. |
#6 |
Drives: 2013 BRZ Limited
Yeah, just find any reputable shop. It took me 45 minutes when I did mine. Pretty sure I could do it in under 30 now, including jacking up the car. There’s no insider Subaru info that’s needed other than the fact that the header is on the bottom (and extremely easy to get to).
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
| The Following User Says Thank You to dasting For This Useful Post: | ZDan (04-26-2021) |
#7 |
Drives: '15 BRZ RA
^The last 2 comments. I did the same some years ago on my dealer. Not a rocket science to change a header on our cars.
| The Following User Says Thank You to nikitopo For This Useful Post: | ZDan (04-26-2021) |
#8 |
Señor Member
Drives: '17 BRZ PP
Yeah I'm gonna side with OP on this one. If you have all the necessary tools and your car is garage kept and your bolts aren't seized and you have some experience then ok maybe you could do this in 30 minutes? It took me several hours due to seized bolts, tight clearances, not having all tools to make it a smooth job and also doing a header change, lifting the engine, and changing engine and transmission mounts for the first time ever on a driveway. For the ACE header you have to lift the engine anyway if you want to fit the ace overpipe but doing the whole thing carefully for the first time will take you several times more what you guys say it took you.
Also he may just not have the chance to miss work and doesn't want to screw his friends over. |
#9 |
Drives: 2017 BRZ Premium
However you choose to have it installed, may be worth giving it another check following install before you're track day. I lost several ace overpipe studs/nuts ending my day at the track early, even after checking fasteners the day before. Others have had similar occurrences, just wanted to share a heads up
https://www.ft86club.com/forums/show...=140823&page=2 |
| The Following User Says Thank You to PLX92 For This Useful Post: | ZDan (04-26-2021) |
#10 |
Drives: 2018 Subaru BRZ
I could help you install it if you'd like. I live near westerly.
| The Following User Says Thank You to spcmafia For This Useful Post: | ZDan (04-26-2021) |
#11 |
Drives: '23 BRZ
Thanks for kind offer! Not likely to be able to get down to Westerly in the next coupla weeks tho. I think I'ma put the car in the air this afternoon/evening and at least get the panels off and see how it goes from there. Days are long enough now, surely I can bust this out over a couple few days...
#12 | |
No problem!. It can go two ways, not raising the engine makes things a bit tricky because of the heat shield from the overpipe. You'd have to remove it which is a pain. After that, if you have an angle socket for the top left (Facing the header up) screw, makes matters easier.
#13 |
Drives: '23 BRZ
Took panels off yesterday afternoon/evening and went for one of the overpipe-to-front-pipe nuts with a 14mm flare wrench, didn't budge, partly rounded the nut, doh! Gonna get some PB-Blaster and hit it again this evening...
#14 | |
Diagonal Pliers come in very handy in this situation, if you're upgrading the OP that is, just tear the heat shield off.
| Good shop for turbo kit install | h@zmat | Arizona | 1 | 06-30-2017 10:36 PM |
| Good body shop in Eastern NC | THEmailman | Southeast | 0 | 01-11-2015 12:10 PM |
| Good shop to do Coilover install | Fallen43 | CANADA | 14 | 06-04-2014 08:30 PM |
| anyone know a good audio install shop | NYCsubaruBRZ | NY / NJ / CT / PA | 6 | 01-16-2014 10:22 AM |
| Good body shop near Boston? | FRiSson | New England | 7 | 04-06-2013 04:33 AM |
