Old 04-20-2021, 02:08 PM   #1
Jasper
Jasper's Avatar
Drives: 2023 GR86
Tire/Wheel Suggestion for FI- 250~300 whp, 225~250 lbft tq
Insight/opinions on wheel and tire sizing, compound, etc. for a rough scenario of 250~300whp and 225~250 lbft tq forced induction- linear powerband?
Primary Usage: Street
Secondary Usage: Track
So a 'Trackable Street Hybrid'
Edit: Mainly focused on sizing.
Jasper is offline   Reply With Quote
Old 04-20-2021, 03:01 PM   #2
dasting
Drives: 2013 BRZ Limited
For what use? Street? Track?
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
The Following User Says Thank You to dasting For This Useful Post:
Jasper (04-20-2021)
Old 04-20-2021, 03:25 PM   #3
Jasper
Jasper's Avatar
Drives: 2023 GR86
Edited, thanks!
Old 04-20-2021, 03:41 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Find a 200tw tire you like. It'll work out
Old 04-20-2021, 03:45 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah ^^^, one of the known-good 200TW tires. Which one depends on how much lap times matter vs. tire life too! I had a better idea when I was driving 500+hp FD RX-7, some tires seem to put power down better than others, but I couldn't tell you which of the current crop is best for this.
Old 04-20-2021, 04:58 PM   #6
Jasper
Jasper's Avatar
Drives: 2023 GR86
What size did you go with?
Old 04-20-2021, 07:25 PM   #7
DarkPira7e
DarkPira7e's Avatar
I haven't gotten to drive on summer tires yet. I had 205/55r16 winter tires that held 3rd gear and up perfectly fine. 2nd gear held if I rolled into it slowly.
I am on Nitto NT05R right now- they haven't been driven on so I can't say how they'll hold. If my winter tires held 330whp in 3rd gear, 200tw on hot pavement should hold 2nd no question unless you have insane torque down low
Old 04-20-2021, 07:45 PM   #8
jflogerzi
jflogerzi's Avatar
Any good 17x9 semi light weight Flow Formed wheel. Lots of good options. Look at the 660's from Falken
2013 Series 10 FRS #553
Old 06-02-2021, 11:33 AM   #9
dencepro
You might want to check out the Cosmis Racing XT-005R rims on 4wheelonline. It's lightweight and makes use of the Flow Form technology.
dencepro is offline   Reply With Quote
Old 06-02-2021, 02:36 PM   #10
jflogerzi
jflogerzi's Avatar
Oh that was directed at the OP. I already have my apex arc-8 wheels
Old 06-02-2021, 02:45 PM   #11
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I am on arc-8 wheels wrapped with Michelin PS4 AS in 245-40/17. I’m using an Edelbrock SC at 246WHP and 220TQ. I haven’t had a slip once and they roll nicely. It was far too much rubber when I was NA
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
edelbrock, forced induction, supercharged, tires, wheels
Performance package wheel/tire weight vs. regular wheel/tire combo qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-26-2019 01:27 AM
Tire Suggestion for new wheels? :) max20s14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 12-12-2016 04:00 PM
New Tire Suggestion FloridaBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-28-2015 11:19 PM
Tire Size Suggestion ExxelDistributions Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-12-2014 07:39 PM
Tire suggestion...245/35/18 with good grip and 20k continuecrushing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-01-2014 07:24 AM
