go_a_way1, MisterSheep
Old 04-16-2021, 06:55 PM   #22989
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
I gave it a good long spray at the car wash. Ran over the remains of a coyote on the way to Des Moines last night and the undercarriage looked like a Tarantino movie. Much better now, and thankfully no real damage that I've noticed so far. I'll have to get under it for a closer inspection once I'm home.
Cephas is offline   Reply With Quote
The Following 2 Users Say Thank You to Cephas For This Useful Post:
ddevl_86 (04-16-2021), Kaotic Lazagna (04-23-2021)
Old 04-16-2021, 08:40 PM   #22990
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Picked up some 8mm spacers. Wanted their V2 version with hub ring for the wheels.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
FLIPDADY (04-23-2021), MJones_RB (04-20-2021)
Old 04-19-2021, 09:35 AM   #22991
DarkSunrise
DarkSunrise's Avatar
Added an alcantara gauge cluster hood from JPM coachworks. Doesn’t really serve any purpose but I love the look haha.
2022 BRZ Build
2013 FR-S Build
The Following 4 Users Say Thank You to DarkSunrise For This Useful Post:
FLIPDADY (04-23-2021), MJones_RB (04-20-2021), RToyo86 (04-19-2021), Wally86 (04-19-2021)
Old 04-19-2021, 09:47 AM   #22992
RToyo86
RToyo86's Avatar
Finally got around to painting my wheel trim black. That about finishes off the interior stuff I wanted to do.
The Following 10 Users Say Thank You to RToyo86 For This Useful Post:
beltax90 (04-20-2021), DarkSunrise (04-19-2021), ddevl_86 (04-19-2021), Decep (04-23-2021), FLIPDADY (04-20-2021), Jordanwolf (04-20-2021), MJones_RB (04-21-2021), theneptune86 (04-19-2021), Wally86 (04-19-2021), wolffbite (04-21-2021)
Old 04-20-2021, 12:02 PM   #22993
Cephas
Cephas's Avatar
Well, it's spring, so I ordered some spring things. Shifter springs, clutch spring, RCE Yellows and B6 kit... Oh and steering rack bushings and oil change kit.
ddevl_86 (04-21-2021), RToyo86 (04-20-2021)
Old 04-20-2021, 01:19 PM   #22994
Jordanwolf
Rice King
Jordanwolf's Avatar
Everyone liked this.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
Old 04-20-2021, 01:47 PM   #22995
RToyo86
RToyo86's Avatar
The site didn't even know what to do with the notification bar.
Old 04-21-2021, 04:34 AM   #22996
takefive
Drives: BMW X6
I'm getting the 3M protective film installed, Spyder Vision tint on the headlights and reverse light cluster (perforated black vinyl - looks dark during the day but lets all the light out), debadging the FR-S badge and swapping the Scion badges for Toyota ones. bitlife pc jiofi.local.html
takefive is offline   Reply With Quote
Old 04-22-2021, 08:12 PM   #22997
Cephas
Cephas's Avatar
Swapped in the MTEC clutch spring tonight. That was a surprising PITA for something that looked so simple! Pleased with the result, though. Pedal feels like it should have all along, and somehow the throw feels shorter?
FLIPDADY (04-23-2021), MJones_RB (04-23-2021)
Old 04-22-2021, 09:09 PM   #22998
RToyo86
RToyo86's Avatar
Got new rubber mounted and an alignment.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
beltax90 (04-22-2021), Celica00 (04-26-2021), Cephas (04-22-2021), FLIPDADY (04-23-2021), MJones_RB (04-23-2021)
Old 04-23-2021, 02:28 PM   #22999
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
That spring makes a big difference, it's impressive how much. You can adjust where your clutch engages, there's plenty of DIY posts here.
The next step is to install the shift spring kit. These springs really improve the shifter feel.
MJones_RB is offline   Reply With Quote
The Following 3 Users Say Thank You to MJones_RB For This Useful Post:
Ash_89 (05-09-2021), Celica00 (04-26-2021), RToyo86 (04-23-2021)
Old 04-23-2021, 03:27 PM   #23000
RToyo86
RToyo86's Avatar
Being able to drive to FT86MS and buy in stock parts is bad for my wallet
Edit agreed about the mtec clutch spring. That was the first mod I did. I ordered it before I took delivery.
The Following User Says Thank You to RToyo86 For This Useful Post:
MJones_RB (04-26-2021)
Old 04-23-2021, 08:29 PM   #23001
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Did you need to get extended studs to run them? Looking to pick them up as well.
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
Old 04-23-2021, 09:45 PM   #23002
RToyo86
RToyo86's Avatar
I did yes. Went with ARP 2.5". Was able to install them on the rear without removing the hub. Required the nipple at the end to be cut off but does the trick.
I wouldn't feel comfortable running anything more than 3mm on the stock studs.
Oh and I installed both the trans bushing and shift springs. Springs were a lot easier than I've read. I used a wire brush on a drill to clean the threads when I took the bolts out and they went back in with no issues.
FLIPDADY (04-25-2021)
