Drives: 2017 BRZ - WRB
Loud Clunk On Driver Suspension When Turning
Hey guys help! Just over a year ago, I had lowering springs installed on my stock suspension and ever since I left the shop, my driver side suspension had single loud clunk/click every time I turn the wheel to the far left.
It has finally driven me crazy and I have my whole car up in the air trying to pinpoint the sound. If my ears aren't playing any tricks, the clunk is coming from the top hat/strut tower area. I tried to tighten the 3 strut tower bolts, but that did not fix the issue. There seems to be no sound when there is no load on the suspension (car in the air and wheel off). However, when the wheel is on or if the car is on the ground, it will clunk. Does anyone know what can potentially be the issue or what I can try to fix this? Here is a video I took that shows the problem. Thank you! ![]() |
#2 |
If it was a shop that did the install, why not take it back for them to assess?
You can see that there's a small round cap in the middle of the strut mount. Remove that and see if the nut underneath is torqued down properly. |
#3 |
Drives: 2015 BRZ
Check your sway bar end-links
#4 |
I ended up taking it to the dealer and they said they will replace the left front strut. Bringing the car in tomorrow, however do you guys think it's a good idea for them to only replace one strut? I'm reading everywhere that it's best to replace them as a pair, but I have no idea if they will agree to that. The struts have about 36k miles on them..
#5 | |
Drives: 2015 BRZ
#6 | |
2013 Series 10 FRS #553
| Clunk noise when turning steering wheel to right | noonedoesnt | Issues | Warranty | Recalls / TSB | 15 | 07-03-2018 09:14 PM |
| Loud Clunk while driving | Flame9020 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-23-2018 09:28 PM |
| Loud clunking underneath driver's side area: suspension, chassis, or wheel related? | loading_please_wait | Issues | Warranty | Recalls / TSB | 4 | 06-18-2015 03:13 PM |
| Loud clunk from rear of car | tennisfreak | Issues | Warranty | Recalls / TSB | 14 | 11-26-2014 12:55 PM |
| Loud pop/clunk under braking. | Panda Grahams | Issues | Warranty | Recalls / TSB | 2 | 07-26-2013 03:13 PM |
