Old 04-16-2021, 02:13 PM   #1
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
What rears to match Stoptech ST-40's 335mm fronts
I plan on running stoptech st-40 fronts at 335mm with Ferodo DS2500 pads.
I know they are pretty well matched for OEM rears, my question is, are the Subaru Brembo rears or 2 pot Rears just as good for bias but an improvement for heat dissipation?
-B
HeresMyMind is offline   Reply With Quote
Old 04-16-2021, 03:05 PM   #2
Racecomp Engineering
Stoptech can probably work with you on a rear kit if you really want it, but it's going to be hard to find large improvements.
Skip the non-brembo OEM Subaru 2 pot rears for sure.
- Andrew
Old 04-16-2021, 07:03 PM   #3
jflogerzi
jflogerzi's Avatar
I would up the pads to be more aggressive if you need better bite in the rear. RR racing does have a rear BBK for our cars that is far cheaper than OEM PP Brembo's just not sure how well they would match up to the stoptechs in the front.
2013 Series 10 FRS #553
RR Racing/ WIlwood Stg 2 fronts and Sport rears cruizin01 Brakes, Suspension, Chassis 6 03-18-2019 08:34 PM
FS: Carbotech XP10 fronts & rears will separate rever5e Brakes, Suspension, Chassis 5 02-15-2015 05:47 PM
Rear Brake Upgrade To Match Stoptech Fronts Pneub Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-10-2014 12:39 PM
FS: Brake pads - Carbotech XP8 rears and OEM fronts d1stance Brakes, Suspension, Chassis 0 12-02-2013 06:20 PM
