Old 04-12-2021, 01:59 PM   #57
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by Adamf220 View Post
Yeah sorry I meant to post, but I talked to the service manager and he said there was no new sway bar mount but the customer service rep said they were working on one so who know. Basically they know this is a common issue and they aren't going to do anything about it.
That's a real shame. I know they just revised the Model number of the Ohlins from SUU MP22 to SUS MP21S1. Brian has confirmed that it's just a UPC addition with no physical changes. From their site it seems like this is something they've started revising since April so i'm inclined to believe him. Although it is odd I could never find spring rates or any technical information about the dampers on Ohlins USA.
Weathers warming up so Im hoping I can get the Ohlins on with the hotchkiss endlinks. Still on oem bars so fingers crossed I don't run into any issues.
RayRay88 is offline   Reply With Quote
Old 04-16-2021, 02:42 PM   #58
Adamf220
Drives: 2013 frs
Here is my solution, 1/2" heim joints with a turnbuckle cut to lenght. Drilled a hole in the A Arm and bolted it up. Had to mount the heim on the inside of the sway bar to clear and it has miles of clearance now. Taking the car to the track tomorrow ill report back on how it works. Should be fine though.
Adamf220 is offline   Reply With Quote
The Following User Says Thank You to Adamf220 For This Useful Post:
RayRay88 (04-16-2021)
Old 04-18-2021, 05:25 PM   #59
jflogerzi
jflogerzi's Avatar
If it works you should charge them a fee for fixing there obviously lack of QC...
2013 Series 10 FRS #553
Old 04-19-2021, 09:44 AM   #60
Adamf220
Drives: 2013 frs
So the new sway bar mounting worked great for me. Zero issues and drove great. I would suggest everyone with ohlins or any other coilovers that have clearance issues to do the same as I did.
Old 04-19-2021, 10:37 AM   #61
Racecomp Engineering
Just be advised that solution does change the motion ratio and effectiveness of the front swaybar, which may be okay with a bigger aftermarket front bar. With a stock front swaybar it might not be okay for everyone.
- Andrew
Old 04-22-2021, 12:25 PM   #62
rixter145
Sleep Chomper
rixter145's Avatar
I added spacers until it clears the endlink now and it's been good with no bump
rixter145 is offline   Reply With Quote
The Following User Says Thank You to rixter145 For This Useful Post:
RayRay88 (04-22-2021)
Old 04-22-2021, 01:34 PM   #63
RayRay88
Spacers beyond what Ohlins provides? What camber are you running and is it through camber bolts or top hats? Also what endlinks, OEM bars or aftermarket?
Old 04-23-2021, 03:50 PM   #64
rixter145
Sleep Chomper
rixter145's Avatar
Fronts right? I'm running the hotchki's endlinks, whiteline sway bars and yeah I just kept adding spacers and checked on full lock (steering) to make sure it clears. I bought my coilover second hand so it never came with the stock spacers, so I just went to hardware store and bought thin ones and kept adding it till it clears.
I had a very aggressive alignment but wasn't tracking enough so I dialed it down a bit. But regardless, no issues at all
Alignment:
RayRay88 (04-24-2021)
Old 04-30-2021, 06:55 AM   #65
maregt
Drives: Subaru BRZ
- Andrew
But the most important question is: is it safe?
I mean, it should be cause the arm is steel but, i don't know, couldn't be better to weld a small bracket on top of the arm?
maregt is offline   Reply With Quote
Old 04-30-2021, 10:05 AM   #66
Adamf220
Drives: 2013 frs
Well I put a full track day on it and am about to do another. Checked everything and its all good. I cant imagine that the forces put on the end link in the control arm are great enough to distort the metal. The WRX is mounted the same way but with a bracket but the steel used for the bracket isnt any thicker than the stamped steel control arm.
Old 05-01-2021, 04:02 PM   #67
maregt
Drives: Subaru BRZ
The wrx arm is fully boxed and the bracket support the link with 2 arms that yes, looks thin, but not from the perspective of the force applied by the sway bar
Ours lca is open at the bottom so if you apply a load to the side the metal can flex cause it's not "supported" at the bottom.
Maybe that much stiffness isn't needed, time will tell (eventually you could put a camera in the wheel well and watch), but it's possible that Subaru used a different construction for a reason
Old 05-03-2021, 09:43 AM   #68
Adamf220
Drives: 2013 frs
Well 2 track days done and its still fine. Subaru used a different construction
on our car because they could. They didnt have to deal with an axle and a
huge transmission so they were able to mount it behind the engine which
from my understanding is a better mounting location. Also I highly doubt
that the sway bar is able to flex the entire control arm, and the hole has not
rounded out or anything so I think its safe to say that it is fine.
Eibach front and rear sway bars MST Engineer Brakes, Suspension, Chassis 3 05-23-2017 12:22 PM
Eibach 29/19mm sway bars Whitel Brakes, Suspension, Chassis 5 01-19-2017 06:17 AM
WTB: Eibach Front and Rear Sway Bars RavioliG Want-To-Buy Requests 2 11-11-2014 01:44 AM
Eibach Front and rear sway bars Review *KID* Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-29-2013 04:14 PM
Eibach Sway bars ON SALE NOW!!! Accurate Race Shop Brakes, Suspension, Chassis 27 11-12-2013 09:51 PM
