Old 04-14-2021, 03:15 AM   #1
TorontoB
Drives: Brz
Junkyard Turbo on stock
What would be the best junkyard Turbo setup for 2.0l boxer engine, Volkswagen 2.0L tsi, or something else?
TorontoB is offline   Reply With Quote
Old 04-14-2021, 07:29 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Junkyard turbos are no different than new turbos. Different shapes, sizes, efficiencies at different power levels.
What goals do you have? How much fab work are you contemplating here? Where physically do you want the turbo to sit?
Old 04-14-2021, 10:28 AM   #3
TorontoB
Drives: Brz
From what I understand of reading threads here and other turbo manufacture kits are con rods are weakest point in making power and that limit is 9 psi. Obviously there is not a junkyard kit that drops in, the least fabrication is always ideal. With these stock parameters in mind.
Old 04-15-2021, 06:12 PM   #4
TorontoB
Drives: Brz
Anyone have suggestions for stock Fa20 turbo?
Old 04-15-2021, 06:55 PM   #5
DarkPira7e
DarkPira7e's Avatar
The gt28 series is pretty great for any aspirations under 400whp
TorontoB (04-15-2021)
Old 04-15-2021, 08:07 PM   #6
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
unless you have fabrication capabilities or know some one that will fab stuff for you, in my opinion it really isn't worth it... especially with JDLs kit hovering around 3k+ and you can get a nice garret GT turbo... gt28/gtx28 like someone mentioned is perfect for anything below 400whp. it'll net you around 330-350whp with e85/flex fuel mix.
pgranberg11 is offline   Reply With Quote
Old 04-15-2021, 10:49 PM   #7
TorontoB
Drives: Brz
Any car comes equipped with gt28?
Old 04-15-2021, 11:10 PM   #8
DarkPira7e
DarkPira7e's Avatar
Yours, if you buy the JDL kit with it.
Why the fascination with junkyard turbos? Almost all of the junkyard turbos are going to have incredibly oddly shaped housings on the compressor and exhaust side, it will be a nightmare.
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
CSG Mike (04-16-2021), PulsarBeeerz (05-03-2021), RToyo86 (05-02-2021), soundman98 (04-15-2021), Wally86 (04-16-2021)
Old 04-18-2021, 10:18 PM   #9
TorontoB
Drives: Brz
Just the price is such a big difference jelly kit is 3-4000 USA currency.
Old 04-18-2021, 11:42 PM   #10
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
probably not.
You'd be better off buying an ebay turbo than finding a good junk yard turbo...Either way you have to be able to fab.
If you want good quality and less expensive AND you can fab. Get an ebay turbo and buy a garrett center section.
If you're going straight up stock on pump gas, a t04b would probably be a safe bet, but not a lot of room for growth.
Jaden
Jaden is offline   Reply With Quote
Old 05-02-2021, 04:28 PM   #11
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
This is what is they list on RockAuto for the 15-20WRX with a turbocharged FA20 engine in it. I think it's the FA20D engine, but a lot of parts are showing FA20E and FA20F as I peruse the different sections. They are out of stock so no price is shown, but they do share the part number.
Mahle/Clevite 745TC23593000
Chasing the part number, Autozone has them for just under $1k. You could call the wrecking yards and likely find one, but the intake plumbing is quite different on that car vs the 86. Also, that engine is at a little lower compression as well, I think 10.5:1, but that won't matter. If you're committed to the junkyard parts bin, find the FA20 turbo charged models and start looking. Kinda looks like it may just be the 15-20 WRX that has it. The STIs bump to a 2.5 liter powerplant. I thought there was one in the Outbacks somewhere, but a quick look proved me wrong.
https://www.autozone.com/external-en...000/187601_0_0
Good luck.
jeepmor is offline   Reply With Quote
Old 05-02-2021, 09:30 PM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Post
FT86MS is doing their own turbo kits now. Check out their site. You can buy a bare bones kit or spec it with some extras, like a the oil pan with fittings welded etc. I think the base kit starts at $4k and you can build from there.
I've seen them on two local cars now. One has a been on a full season.
Base turbo is a GT2860RS
https://www.ft86motorsports.com/ft86...rs-brz-86.html
RToyo86 is online now   Reply With Quote
Junkyard motor in a clean title frs. Donovan34 Issues | Warranty | Recalls / TSB 8 09-25-2017 04:56 PM
Toyota/Lexus 4.56 FD, Torsen LSD, direct bolt-on, junkyard pumpkin thread fooddude Engine, Exhaust, Transmission 19 03-15-2014 04:57 PM
AVO Turbo Kit IN STOCK! Xero-Limit Forced Induction 0 10-03-2013 10:46 PM
Achievement unlocked: Save an AE86 from the junkyard yurikaze Member's Car Journals 19 02-19-2013 11:20 PM
