Add HP/torque 2013 FRS
So I was planning on waiting for the rumored Turbo 86 but unfortunately, it was just a rumor. Most likely, since Covid hit and my finances also took a hit, I am looking for the best/cheapest way to get the car hp to 200whp without using an expensive forced induction kit. Is it even possible and if so, what needs to be upgraded to get there? Thanks
#2 |
Drives: FRS Hot Lava
Decatt OEM header (you will spend $25 in new gasket)
OFT used ($350/$400) E85 if available in your area. |
| The Following 2 Users Say Thank You to fminicooper For This Useful Post: | NoHaveMSG (04-15-2021), x808drifter (04-15-2021) |
#3 |
Drives: Crapcan
/endthread
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | x808drifter (04-15-2021) |
#4 |
I have the OFT already and running on e85 adds (total guess, 15-20 HP) but there are not enough stations that sell e85 around me which is a problem. Would a flex fuel kit solve this issue so I do not have to plan everything around when I need to add fuel.
#5 | |
https://www.ebay.com/itm/Toyota-GT86...0AAOSwJ8pbbM4b |
#6 |
Drives: FR-S,GTI
Keep your eye out for a used Phantom ESC. Should get you up to about 200 WHP about the cheapest way you can go. And it can be installed/deinstalled pretty easily.
| The Following User Says Thank You to WNDSRFR For This Useful Post: | Riftur (04-15-2021) |
#7 |
Drives: 2017 BRZ PP, 2004 WRX
E85 is going to be the easiest way to get 200whp and safely. But if it's not available....
The alternative is a EL header like the Ace A350 (pricey), 93 octane: https://www.ft86club.com/forums/showthread.php?t=121460 According to this thread, 91 octane is going to net you 195whp here, so 93 might get you the extra 5. Either way, it's at last in the ballpark and not going the e85 route. Alternatively, you're looking at a flex fuel kit and running e85 when you can get it, which should put you over the 200whp barrier.
#8 | |
#9 | |
https://www.ft86club.com/forums/showthread.php?t=144933 |
#11 |
Drives: brz 2017 hksv2
true, pretty easy to reach MBT while NA with pure e85 also with a cat
the gains would be marginal |
#12 | ||
Drives: 2014 Ultramarine FR-S
#13 | |
Thanks! |
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
| Why the low torque? | Ds3ire | Scion FR-S / Toyota 86 GT86 General Forum | 144 | 11-28-2014 11:49 AM |
| Torque Dip | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 68 | 07-22-2013 03:18 PM |
| torque | mrnibbs | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-13-2013 09:37 PM |
