Old 04-13-2021, 10:46 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I, too, may be in the market for such wheels having sold my RPF1 17x9 +35 wheels.
Something 17x8 with 35~40 offset should be plenty clearance even with high negative camber settings in the front. Also for a flush-er fitment relative to most wheels this size with a higher than 40mm offset.
Konig seems to have some in a +40mm in 17x8 wheels flow formed.
https://konigwheels.com/wheels/flow-...eels/dekagram/
Really like the look (particularly the detail in the spokes) of these and the price, but they are cast aluminum, and they dont come in 5X100 in the 17x8. Information about weight is unavailable, not that it matters since they dont have the right lug pattern. https://www.avid1wheels.com/wheel-mo...40-hyper-black
Intent > Content
Old 04-13-2021, 11:25 PM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
I think most of their wheels require spline drive lug nuts. I'm not sure about that but you may want to look into it. I hate fiddling with those things.
Old 04-13-2021, 11:27 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by bucketfoot View Post
Any feedback on how O.Z. wheels are?
Looks like the Ultraleggera is available in a 17x7.5 with a +35 offset and are 17lbs. They are a bit more expensive, but not too bad.
I had Superleggeras on my A4. I really liked them. I think the ultras are the replacement for those wheels. They've been around a long time but I have not heard many complaints about them.
The Following User Says Thank You to Pat For This Useful Post:
Transport3r (04-14-2021)
Old 04-14-2021, 01:41 AM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
16ul
http://949racing.com/17x8-6UL-5Lug.aspx
Not sure why you want such a low offset, 5mm spacer and slightly longer studs, spacer will be a handling tuning tool if you decide to use the motorsports wheels for motorsports.
ineedyourdiddly
Old 04-14-2021, 08:54 AM   #19
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Originally Posted by jflogerzi View Post
What offset you looking for?
First choice would be 35, but I'd be good with something between 35-40.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 04-14-2021, 09:15 AM   #20
bucketfoot
bucketfoot's Avatar
I've only had the car for two weeks, so I haven't had the time to look at things like wheel clearances.
How much room is there to the inside and what is the widest tire size I could use with the OEM 48mm offset?
Hell, you guys all know way more about the car than I do. What are the recommended offsets for a 17x8 wheel?
I went with an 8" as I know I can easily fit anything from a 225 to a 245 on it.
Old 04-14-2021, 09:45 AM   #21
jflogerzi
jflogerzi's Avatar
245 will be pinched on an 8 inch. Hence just go with 17x9 and be done with it
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
ZDan (04-14-2021)
Old 04-14-2021, 10:11 AM   #22
Vital
Drives: 2015 BRZ
Hmm the widest tire you could probably put with a +48 offset on stock suspension might be a 235/40/17 and that tire size has very limited options. But it is hard to answer this question without knowing your suspension as getting coilovers, springs, wheel offset all become a factor for clearance depending on your suspension.
Typically for a car that is lowered 1" a 17x8 +35 offset will get you flush fitment. Here is a thread of the Konig Dekgrams my car is posted on the second page for reference. The Konig Dekagrams i have are 17x8 +40 and im using 245/40/17 tires and i really dont think the tire looks pinched it looks fine.
https://www.ft86club.com/forums/show...=134664&page=2
Old 04-14-2021, 10:42 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
16ul
After I bought my 6ULs I became aware of cracking being an issue on tracked cars. I have done ~10 track days on mine, just did an inspection and sure enough I see hairline cracks starting on the inside of one spoke on three of my wheels. Small enough that I might not notice if I werent' looking hard, but the location is exactly where wheels are known to crack and fail. Doh...
Anyway, I'd stay away if tracking...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Ohio Enthusiast (04-14-2021), strat61caster (04-14-2021)
Old 04-14-2021, 10:47 AM   #24
Transport3r
Drives: -
Same, had ultralegerras on my TT from 2007-2010. Great light wheels, can shrug off a decent pothole. Pain to clean though.
Transport3r is offline   Reply With Quote
Old 04-14-2021, 10:49 AM   #25
Transport3r
Drives: -
Yes, I bought a car with 245s on 8” wheels once. On center steering was awful cause the tire was flopping back and forth on the wheels. Switched to 235s and it was fixed.
Old 04-14-2021, 10:53 AM   #26
bucketfoot
bucketfoot's Avatar
I ran 245s on a 7.5 inch wheel on my BMW for years with zero issues. So I have no concerns with running them on an 8 inch.
Throw in that I honestly do not know that I will ever go beyond a 225 and a 9 inch wheel just does not make sense for me.
I'd love to just say screw it and get another set of ARC-8s, but they do not make sense for me.
Old 04-14-2021, 10:55 AM   #27
bucketfoot
bucketfoot's Avatar
Great info, as tracking (HPDE and possibly 86CUP down the road) is most definitely in my plans
Old 04-14-2021, 11:00 AM   #28
bucketfoot
bucketfoot's Avatar
My plans are to do nothing major with the suspension. The car needs to remain something that my wife is comfortable riding in (a horribly rough ride was the major reason she hated my BMW). So something like Bilsteins down the road, but nothing that will have a negative ride impact.
Alternatives to AX-SUB28SWC-6V? brzsubie Electronics | Audio | NAV | Infotainment 2 10-23-2017 12:55 PM
Cheap UEL alternatives? haavardnk Engine, Exhaust, Transmission 34 10-05-2016 09:56 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 12:59 AM
Alternatives to BRZ, sub $30k zygrene Other Vehicles & General Automotive Discussions 123 05-08-2012 12:23 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 04:27 PM
