Old 04-13-2021, 11:56 AM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
Wow what an interesting weekend
So this weekend I sold my Hellcat and decided to upgrade my Twin. I went ahead and dumped my 15 FRS (which had a very VERY rough life prior to me as you can see from my earlier posts) and traded it up new 2020 stripped down 86 because not counting the trade in I got it for 25k.
So I have some money to play with for the track car... I still have the XP10's and XP8's I never installed on the FRS so those are gonna go on the 86. I'm also gonna get some 57CR's in 17x9 and Falken 660's. Maybe an Oil cooler as well. I'm also thinking about getting a front splitter and wing from Verus just because it'll give me a little more traction.
I'm gonna wait till my track game gets a little stronger before I start going too hard core on suspension.
I could care less about power or sound for at least the time being.
Anyone have any recommendations?
Jstyle is offline   Reply With Quote
The Following User Says Thank You to Jstyle For This Useful Post:
Wally86 (04-14-2021)
Old 04-13-2021, 12:45 PM   #2
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Y not wait for the new twins?
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 04-13-2021, 02:12 PM   #3
macuser27
macuser27's Avatar
Sounds like a good plan: brakes, wheels/tires, oil cooler. However, I suggest suspension and alignment (more camber) before aero. My 2¢
macuser27 is offline   Reply With Quote
The Following 3 Users Say Thank You to macuser27 For This Useful Post:
Breezio (04-13-2021), strat61caster (04-13-2021), timurrrr (04-21-2021)
Old 04-13-2021, 02:18 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
lol first year new engine design from Subaru in a track car? pass
Unfortunately won't be able to get much camber with the 17x9's without doing top hats, maybe the pedders and a cam bolt could get you over -2 though, it'll pay for itself by the second set of tires, rear LCA's will be desired eventually might as well only align it once.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
KR-S (04-13-2021), Lonewolf (04-19-2021), timurrrr (04-21-2021), Wally86 (04-14-2021)
Old 04-13-2021, 06:40 PM   #5
Jstyle
Jstyle's Avatar
Drives: 2020 86
Agreed... That’s why I didn’t wait. I’ll let other owners grenade their engines\trannies\whatever through the first year and look at it the second.
So I kinda understand the idea behind camber. The idea is you tilt the tops of the wheels in or give you better traction. I know cam bolts are literally 1/10 of the price of new camber plates.. what’s the big advantage to getting camber plates as opposed to just getting bolts? Why would I need whole new LCA’s?
Old 04-13-2021, 06:41 PM   #6
Jstyle
Jstyle's Avatar
Drives: 2020 86
Also what are top hats?
Sorry for the newb questions... not new to racing... I am new to racing on 4 wheels.
Old 04-13-2021, 07:30 PM   #7
Snake
Drives: ADM Toyota 86 GT
Depending on the tyres you're running an how aggressively you're driving, these things need well in excess of -3 degrees camber on the front not to absolutely ruin the edge of your tyres. With camber bolts you'll get maybe 1-1.5 degrees, then with top mounts you'll get that up to around 3-3.5 degrees depending on the mounts.
Adjustable top mounts are mounts for the top of the shock that can move where the top of the shock is located. This gives you additional camber and caster adjustment. They generally come with a set of coil over suspension, although you can just buy the top mounts by themselves.
If you want to go above 3.5 degrees, you'd need to get front lower control arms.
This is all in my experience with Whiteline camber bolts and shockworks coilovers/adjustable top mounts running z221 semis on the track with likely too aggressive a driving style.
Sent from my CPH1979 using Tapatalk
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
Jstyle (04-14-2021)
Old 04-13-2021, 07:41 PM   #8
strat61caster
Camber plates offer more range, as mentioned -3 is a nice starting point for the front, I'm at -4 right now which you can't get with just bolts, as above suspension choice dictates what you need to do to get an aggressive alignment, lcas aren't necessary to hit -5 if the struts are designed for it.
Also given your planned wheel choice you will be limited by wheel to spring perch clearance when using camber bolts, you will not be able to hit -3 without camber plates or a camber adding top hat like pedders.
The rear is not camber adjustable from the factory, you need adjustable lower control arms to align the rear properly on this car.
This does the job for most people:
https://www.spcalignment.com/compone...tion&pid=67660
Top hats are the plates that mount the damper to the chassis, just another name for them. Camber adjustable top hats might be more proper then camber plates but meh who cares.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Jstyle (04-14-2021), macuser27 (04-14-2021)
Old 04-13-2021, 07:42 PM   #9
strat61caster
Useful thread
https://www.ft86club.com/forums/show....php?p=2600171
ineedyourdiddly
Jstyle (04-14-2021)
Old 04-13-2021, 08:15 PM   #10
jflogerzi
jflogerzi's Avatar
Here is what I would do to be honest in this order:
Oil Cooler
Coils with Camber: Look at RCE SS-1s or CSG Tien Flex A's(do it once and be done)
Rear LCA's
Track Alignment at a good shop (aim for -3 up front and -2 or -2.1 rear)
Wheel and tire Package 17x9 and a 235-245 size tire
Use Carbotech's for Track. Get second pair of rotors to swap with the pads so you can re-use stock pads on the street(quiet and dust free)
Brake Ducts
Don't mess with Aero yet.
2013 Series 10 FRS #553
Old 04-13-2021, 08:38 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
My 0.02: rear LCAs in my case were unnecessary. I'm at -2.7 rear camber at -1.25", pretty much right where I want to be.
Old 04-14-2021, 08:18 AM   #12
M0nk3y
If you're going to run any sort of Aero package the stock suspension is not enough to handle the amount of downforce being generated. For camber, compression and rebound valving, spring rate...etc
With that being said, I think Aero is a pretty big step from a light track build to something a bit more serious.
Kyle H. - #89 STX
Old 04-14-2021, 09:14 AM   #13
Jstyle
Jstyle's Avatar
Drives: 2020 86
Oil Cooler
Rear LCA's
Brake Ducts
If I go with the CSG Tien's and add LCA's... I don't need camber plates anymore then do I?
Old 04-14-2021, 09:43 AM   #14
jflogerzi
jflogerzi's Avatar
Yes correct because they already come with camber plates
Interesting... Boomerang BRZ Photos, Videos, Wallpapers, Gallery Forum 10 12-19-2018 04:35 PM
This looks interesting g e BRZ First-Gen (2012+) — General Topics 4 02-13-2018 04:03 PM
The most interesting swap? Cuchullain Engine Swaps 10 08-16-2014 07:41 PM
All British Car Weekend THIS Labor Day weekend stockysnail Northwest 5 09-05-2013 03:10 AM
Why ft-86 is interesting? NewCarInQ42011 Scion FR-S / Toyota 86 GT86 General Forum 69 11-26-2010 04:05 PM
