Old 04-08-2021, 01:23 PM   #1
SwiTchY86
Drives: GT86
Need advice on tire dimensions for a staggered setup
Hello everyone,
I need help with calculating tire sizes for a staggered setup. I've ordered Rota Grids - Front: 18x8.5 5x100 ET44, Rear: 18x9.5 5x100 ET38.
Since I'm still waiting for my wheels to arrive, I'm having trouble deciding with tire sizes.
I did some research and I couldn't find any reasonable anwsers, but I was thinking of going 225/40R18 for the front and 245/40R18 for the rear.
Should I be looking at 245/35R18 at the rear? I am going for a bit of a stretch on the tires, so no need for extra wide tires.
Any help or tips appreciated.
Thanks in advance!
Edit: I am running BC Racing coilovers and haven't touched the ride height yet. It is sitting at the height at which coilovers come from the factory. Will be looking for a nice, flush fitment.
SwiTchY86 is offline   Reply With Quote
Old 04-08-2021, 03:33 PM   #2
gpvecchi
gpvecchi's Avatar
9.5x18 ET 38 will poke out from wheel arches...
Old 04-09-2021, 06:46 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
My advise would be to not do staggered setup, but it came too late, as you have already ordered wheels.
Old 04-09-2021, 07:01 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Save yourself grief and take the wheels back and go square setup.
TommyW is offline   Reply With Quote
Old 04-09-2021, 07:33 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
215/245 or 225/255 need same diameter.
225 squared is classic NA setup
245 squared classic FI setup
225/255 is for the bad ass FI setups.
Old 04-09-2021, 07:36 PM   #6
86TOYO2k17
In the rear with a 245 it will be pretty flush with about -1.5 degree camber, 255 will poke unless he does more camber
fitment, staggered, tires
Winter tire setup - thoughts&advice airdaddy CANADA 25 10-08-2020 10:50 PM
Staggered setup McG86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-11-2016 02:06 PM
Advice on Tire setup otterpop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-11-2015 12:50 PM
staggered setup - how's the tire wear? cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2013 12:27 PM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
