Old 04-06-2021, 02:30 PM   #1
Jreyes96
Rapid clicking noise 2.5-4K rpm
Needing some help.. just got my car back from a shop (replaced engine ‘13 to ‘15) and it’s making a clicking noise from around 2500-4000 rpm and I get a faint smell of exhaust. I read online that it could be the exhaust manifold gasket, but wanted a 2nd opinion if anyone had this issue before. Also, would I need to re-tune the ecu?
I would attach a video, but there isn’t a way to on the forum.
Jreyes96 is offline   Reply With Quote
The Following User Says Thank You to Jreyes96 For This Useful Post:
humfrz (04-08-2021)
Old 04-08-2021, 04:14 AM   #2
Well, Jreyes96, the first thing I would do it to take the car back to the shop that replaced the engine and ask them to check it out and fix it.
As far as the ECU, as long as they used the one that came with the new engine and the car is running good, I reckon it's good to go.
DarkPira7e (04-08-2021)
Old 04-08-2021, 07:15 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Does it do it when you rev sitting still? Or more prominent under load while driving?
Old 04-09-2021, 12:48 PM   #4
Jreyes96
Yeah, that’s definitely the plan. I was just trying to get an idea of what problem I may be looking at.
Old 04-09-2021, 12:49 PM   #5
Jreyes96
It’s only during acceleration. It’s only around 2500-4000 rpm, it gets louder the closer I get to 4000. It’s also got a slightly rough idle.
Old 04-09-2021, 02:58 PM   #6
tomm.brz
Drives: brz 2017 hksv2
post logs...
Old 04-09-2021, 04:09 PM   #7
jflogerzi
jflogerzi's Avatar
Don't drive it any more. Have towed back to the shop. The less mileage the better off you will be.
2013 Series 10 FRS #553
Old 04-28-2021, 09:04 PM   #8
MrSir
Gentleman/scholar
MrSir's Avatar
Drives: 13 FRS, 89 RX 3dr, 00 gf8, 73 F250,
Clicking 2.5-4K is much more extensive than I’ve dealt with, however......
All of the 4 cylinder Subaru’s I own, all of the 4 cylinder Subaru’s I’ve driven, and all of the 4 cylinder Subaru’s I’ve worked on, twerk and click mildly between 1.5-2.5k depending on which specific engine designation it is. It’s that good old Subaru engine noise, separate from the exhaust noise. (Torsional imbalance? Harmonic resonance? Idk...)
So, in the event that it checks out with a clean bill of health, this is just something we deal with.
Just glassin
73 F250 CSR 390 4otf in metallic sativa; 89 RX turbo fastback hs 1/2600 never ending project; 00 Impreza L 2.2 with a bazillion miles; 13 FRS Ultimate gokart daily; 16 Impreza sport hatch 2.slow for groceries
MrSir is offline   Reply With Quote
Clicking noise while idling Smking0212 Issues | Warranty | Recalls / TSB 12 11-12-2020 01:52 AM
Car won't start no clicking noise randomweather Issues | Warranty | Recalls / TSB 13 07-04-2020 05:30 PM
What is this OTHER clicking noise? radroach Issues | Warranty | Recalls / TSB 0 02-16-2019 02:10 PM
Clicking noise in engine bay teddydoggy Issues | Warranty | Recalls / TSB 4 08-12-2013 05:15 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
