Old 04-07-2021, 01:46 PM   #1
Kalebhall
Drives: 2013 Subaru BRZ limited
Is this normal?
I noticed when taking off my charge pipe that the turbo oil inlet line has burned through this pipe. Is this normal should it be getting this hot?
Kalebhall is offline   Reply With Quote
Old 04-07-2021, 09:47 PM   #2
Z06ZN6
Drives: 2017 Toyota 86
Probably abraded it rather than burned it.
Metal braided lines are very abrasive so its always best to insulate them where there is contact or possible contact with something nearby.
Z06ZN6 is offline   Reply With Quote
The Following User Says Thank You to Z06ZN6 For This Useful Post:
Irace86.2.0 (04-08-2021)
Old 04-08-2021, 01:49 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Agreed, but it is hard to tell. Is the pipe wrapped with heat reflective tape or is that just some type of duct tape? It looks like it wore through the tape and the metal from friction. It looks like it melted because of the impression from the braided band, but that is just micro vibrations creating that effect.
On a separate note, the oil line will get very, very hot, but not hot enough to melt metal. If it did then I would imagine it would melt before melting something else.
Old 04-09-2021, 05:57 PM   #4
Grady
Grady's Avatar
Yes that is normal chafe mark. You need to secure you lines better to keep this from happening.
Old 09-24-2022, 10:28 AM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I don`t like the path of the oil feed line. ie Right over the hottest part of the turbo. A more direct path may fix the rubbing and avoid getting cooked.
Is this engine noise normal? (Consensus - normal) StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 31 02-05-2018 03:01 PM
Is this normal? Impureclient Engine, Exhaust, Transmission 3 12-08-2017 09:47 AM
Is this normal? OFT Sovereign Scion FR-S / Toyota 86 GT86 General Forum 2 06-24-2015 03:31 PM
IS IT NORMAL WGMGR Scion FR-S / Toyota 86 GT86 General Forum 40 12-08-2014 05:19 PM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 02:54 AM
