Old 04-07-2021, 12:47 PM   #29
The young @Tcoat walks into the local corner garage/gas station. The old timers are sitting around chewing tobacco and ask him if they could help him. Tcoat, rubbing is sore wrist and arm, asks "why is it that every time I go to start my automobile, the crank kicks back and hurts my wrist and arm"?
The one ol boy, wearing bib overalls, leans over, spits tobacco into a coffee can and asks "do you set the spark (full retard position) before you attempt to crank start it?"
Tcoat, being defensive, blurts out "are you calling me a retard?" The old boy sticks another wad of tobacco in his mouth and says "nooooo not YOU, the spark advance lever", as he
Young Tcoat - oh, ya, ................ now, is the spark advance lever supposed to be all the way down or all the way up?
The one ol boy turns to his buddies and says "in the last 30 years, that if he had a dime for every kid that came around here and asked that question, he would have enough money to buy a brand new Stutz Bearcat" -
The proper term these days would be "spark challenged"!
humfrz (04-07-2021), soundman98 (04-07-2021)
Old 04-07-2021, 09:25 PM   #30
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by FR-S2GT86 View Post
Does anyone know if there is a minimum voltage requirement that the ECU must see in order for it to allow a crank attempt to be made? Like a low voltage safety? And does it apply to both key start and push-button start cars?
you're confusing voltage and current. voltage is like the boss, and current is like the workers. the brick wall doesn't get built if the boss isn't around, but the boss doesn't lift a finger when he's around either, but is there to motivate the workers to get stuff done.
there's a minimum current requirement to the system. the starter won't turn. otherwise, the rest of the system-- the ecu, and relays, are all low current, automotive voltage rated devices. so they'll comfortably operate down to around 9 volts.
Old 04-08-2021, 12:58 AM   #31
Bmertens
Drives: Murdered 2015 Frs
Talking
Well?
Sorry too keep you waiting ! Car is fixed !!!! Took a step back and realized I overlooked the fuses on the positive terminal which were blown probably while i was taking the negative off the battery. Cold air intake and tune make a helluva difference. Thanks for y’all’s help and input.
Bmertens is offline   Reply With Quote
The Following 3 Users Say Thank You to Bmertens For This Useful Post:
humfrz (04-08-2021), soundman98 (04-08-2021), Tcoat (04-08-2021)
Old 04-08-2021, 02:47 AM   #32
Well, thanks for getting back to us.
- that's for not payen attention to what ol @soundman98 told you up in post #4 ("did you check the fuses on top of the battery?")
Now, iffen you think the aftermarket CAI makes a "helluva" difference, that is OK - jest be calling out and Mustangs, just because you have a CIA -
Now that's one brain fart that you have used up on here -
Old 04-08-2021, 08:15 PM   #33
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
COMBO WRENCH TEST
x808drifter: "The right way to do it is with a combo wrench"
Sorry, the Snap-On tool fails the battery test:
ToySub1946 is offline   Reply With Quote
The Following 2 Users Say Thank You to ToySub1946 For This Useful Post:
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 04:17 PM
(S)he's dead, Jim. D.Scrye Scion FR-S / Toyota 86 GT86 General Forum 37 02-11-2016 03:40 PM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 04:06 PM
The Walking Dead RAP ThreeZzZ Off-Topic Lounge [WARNING: NO POLITICS] 1 01-12-2015 05:43 PM
