Old 04-04-2021, 01:49 PM   #22933
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Always trying to improve my shifting and I have a question around coming to a stop in-gear.
For safety and wear (brakes) reasons, I do not coast into a stop sign. My typical method now when coming to a stop from around 50mph
5th, 4th, 3rd; roll to a stop in 3rd till around 900rpm then push in the clutch. This puts me around 10-15 mph.
Is anyone downshifting all the way to 2nd before a stop? Seems excessive, but maybe I am being lazy.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-04-2021, 03:06 PM   #22934
Kaotic Lazagna
Drives: GR Corolla
I engine brake as much as possible. If there are cars behind me, I'll just use 3rd to get down to about 1k rpm. If there is no one behind me, I'll use 2nd from around 20 mph down to around 10 mph or so.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
BrahmaBull1990 (04-04-2021)
Old 04-04-2021, 03:34 PM   #22935
LancePower
Drives: 2020 BRZ tS
I'd rather wear out my Brakes (cheap) than any associated Clutch/Trans parts (expensive).
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
DarkPira7e (04-04-2021)
Old 04-04-2021, 03:37 PM   #22936
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Engine braking is not going to hurt the transmission, IMO. Automatics do it already, you just do not notice.
The idea is you let the engine rev-down AND brake.
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
theneptune86 (04-06-2021)
Old 04-04-2021, 03:54 PM   #22937
Kaotic Lazagna
Drives: GR Corolla
Only way I really see any excessive wear on the trans is if you don't rev match when downshifting.
Old 04-04-2021, 09:36 PM   #22938
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Just picked up this book, too, today.
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
JD001 (04-05-2021), soundman98 (04-04-2021)
Old 04-04-2021, 10:12 PM   #22939
Purist
Purist's Avatar
Drives: Subaru BRZ
It's not a sequential box so no need to go through all the gears. I often do 3-1 shifts on at the end of short straights into hairpins.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
Old 04-04-2021, 10:45 PM   #22940
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I share this sentiment. If I'm coming to a stop sign, I'm doing so in neutral. No reason to engine brake if you're coming to a complete stop. As above, I'd rather put heat and friction wear on the system designed for that exact purpose
LancePower (04-05-2021)
Old 04-04-2021, 11:08 PM   #22941
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Why is pad braking and engine braking mutually exclusive?
“Engine braking occurs when a driver takes their foot off the throttle. The throttle valve closes, a vacuum forms and the engine slows the car down. This is the same case in a manual transmission. It’s often been rumored that engine braking is bad for your car, but it can actually prove beneficial, as Fenske explains in the video.”
Old 04-04-2021, 11:24 PM   #22942
DarkPira7e
DarkPira7e's Avatar
I didn't say that it does not have a place. Just that I don't downshift for the sole purpose of bringing the car to a stop
Old 04-05-2021, 11:22 AM   #22943
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Originally Posted by CrazyOkie View Post
So technically I didn't do it, but the dealer finished the install of the TRD parts I'd purchased with my 86 GT. 17" wheels, performance exhaust and sway bars were installed two weeks ago. Yesterday was the springs. At least for the moment she's complete. Debating whether to get the cold air intake installed, but that will probably wait 6-12 months.
Is that photo before or after the springs? Also I'm in love with that color.
I'd skip the intake, FWIW. Not much to be had over just doing a tube and a drop in for far less cash.
Originally Posted by Stephen W. View Post
If so I hope Toyota have fixed the issue with the finish clear coat peeling off over time.
Might just be a midwest/high salt area thing, but Toyota's clearcoat on their wheels just doesn't last. I've had two sets on my Tacoma start bubbling after a few seasons, and just noticed the stock wheels on my 86 are starting to bubble around the center caps.
Cephas is offline   Reply With Quote
Old 04-05-2021, 04:36 PM   #22944
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
Put on some XP10 pads in preparation for my first track day and they’re loud as hell. I sound like a school bus coming to a stop.
jkamelo is offline   Reply With Quote
The Following User Says Thank You to jkamelo For This Useful Post:
BrahmaBull1990 (04-05-2021)
Old 04-05-2021, 05:09 PM   #22945
jflogerzi
jflogerzi's Avatar
Yup... You don't want to drive these on the street
2013 Series 10 FRS #553
Old 04-05-2021, 07:08 PM   #22946
ddevl_86
theddevilinme
ddevl_86's Avatar
Drives: 2013 Scion FRS [H8R]
Got a sweet re-usable/washable air filter in the mail today from ProTuningLab ($25!)
This weekend is gonna be fun putting on the drive belt, removing stock air intake/filter, and adding the drop in filter + Perrin inlet tube! Also gonna paint up the alternator and water pump plastic covers with VHT Metallic Copper. Maybe I'll do the battery tiedown too and re-install it. I havent had it on the last year as it's rusted and ugly. Almost the same color anyways haha
Going to the local Subaru dealer to pick up some other items tomorrow. Fender garnish clips, 2gal Super Coolant, Left Cowl cover, and a bumper cover spacer panel for the front Probably a good idea to ask for some clips to install them back with before I leave...
We're all just living to die - might as well enjoy the ride!
ddevl_86 is offline   Reply With Quote
