#15 |
Drives: 2017 BRZ Premium
If you’re goal is to only lower about an inch, you can likely get away with the stock arms.
For what it’s worth, going from oem suspension to coilovers + camber plates, I didn’t notice any significant impact to nvh as I have on other platforms. My vote would be the RCE ss’s and just reuse stock rear arms. |
| The Following User Says Thank You to PLX92 For This Useful Post: | Tatsu333 (04-02-2021) |
#16 | ||
Drives: 2020 BRZ Sport Tech RS
What I'll probably do is drop the car first and see where the rear camber ends up. I'll aim to get about the same negative camber in the front to begin with and then adjust from there based on tire wear and handling balance. If I can get away without doing the rear arms, that will definitely help with the budget!
#17 |
Howdy
Drives: 2020 BRZ PP
Just installed the RCE Superstreets and they are amazing. ZERO body roll and the ride drop is perfect. They feel just as good, if not a bit softer, than the PP McPherson struts over bumps
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
| The Following 3 Users Say Thank You to BrahmaBull1990 For This Useful Post: |
#18 |
Just curious - what do you have the dampers set at front and rear?
#19 |
Howdy
Drives: 2020 BRZ PP
There is 20 clicks of range so I just did 10
| The Following User Says Thank You to BrahmaBull1990 For This Useful Post: | Tatsu333 (04-04-2021) |
#20 | |
Drives: 2020 Toyota 86 GT 6M
The boot was a complete bitch to get on though but def a lot more durable/stretchy than i gave credit for. Second time i put it back on i just stretched it a lot more over everything and was done with it in a minute. First time i swear it took me 45 mins cursing to get it on. Only to find a washer from one end of the pin rod on my drive way after i bolted everything back up so had to tear everything down to put it back in lol. ALWAYS TRIPLE CHECK YOU HAVE ALL THE WASHERS IN PLACE BEFORE PINNING THE ROD AND PUTTING THE DUST BOOT ON! lol The FTSpeed install videos never showed the pain in the ass dust boot since the aftermarket short shifter they showed in the videos did not include them. |
| The Following User Says Thank You to saltywetman For This Useful Post: | Tatsu333 (04-05-2021) |
#21 | |
#22 |
One other small mod I did a while back but forgot to journal was plugging the sound tube hole in the firewall. I bought a cheap PVC pipe plug from the local Home Depot (I *think* it was a 3/4" plug) for less than $2.
It definitely takes the edge off the harshness of the engine note in the 3500 rpm range and makes a small difference in overall volume, so I'd recommend it for sure! I'm still kind of on the fence whether or not I'll stay NA with the car long-term, or go with the Edelbrock supercharger. If I stay NA, I'll most likely grab the Perrin intake tube to more cleanly replace the "sound generator" apparatus completely.
#23 |
Latest mod - installed the auto-dimming mirror. This only took so long to get done because the dealer forgot to include the mounting adapter when the accessory was added to my original purchase, and then once I figured out that I had to order that, I wasn't able to pick it up from the dealer for 2-1/2 months due to COVID restrictions...LOL!
Installation was SUPER easy... ![]() I also picked up some SPC camber bolts, and will try to have the alignment done next week or the week after, aiming for zero toe front, slight toe in (within factory specs) rear, and matching front negative camber to whatever the rear is sitting at.
#24 |
So my wife surprised me with some new wheels for the BRZ for my upcoming birthday! 17x8" ET35 Fast Wheels FC04 in Titanium, with black McGard Spline Drive wheel nuts. The new wheels are fitted with the same Pirelli P Zero All Season Plus 225/45R-17 tires I was running on the stock Performance Pack wheels.
These are the same wheels I had on my Tiburon (but different bolt pattern, obviously), and I liked them so much, I (we) bought them twice! Nice and light at a touch over 17 lbs. per wheel due to their flow-formed casting, and I never had any issues with my old set in 4-5 years of owning them. LOTS of clearance to the Sport Tech RS / Performance Pack Brembo's, with 7mm of space at the closest point where the spokes curve in and over 15mm mid-spoke. Also plenty of clearance to the barrel. On stock alignment, this wheel/tire combo is EXACTLY flush in the front, and a few mm tucked at the top in the rear. I'll be (finally) doing an alignment next week to dial in some negative camber in the front and zero out the toe all around, so that should even things out appearance wise as well as improving the handling balance. ![]() Here are some pics: Side View: ![]() Front 3/4 View: ![]() Rear 3/4 View: ![]() FLUSH in Front: ![]() Near Flush in Rear: ![]() Brake Clearance: ![]() ![]()
| The Following User Says Thank You to Tatsu333 For This Useful Post: | SuperTom (05-11-2025) |
#25 | |
Drives: 2018 Subaru BRZ Limited with PP
| The Following User Says Thank You to Dzmitry For This Useful Post: | Tatsu333 (08-18-2021) |
#26 | |
![]() They're also pretty inexpensive - we paid less than $900 Canadian shipped for the set. EDIT: Ultimately, I'm going to get 18's with the same wheels - either 18x8" ET40 with 225/40R-18's or 18x9" ET40 with 255/35R-18's. That will be WAY down the road though. More suspension work and possibly supercharging will happen before that.
| The Following User Says Thank You to Tatsu333 For This Useful Post: | Dzmitry (08-19-2021) |
#27 |
One small update for today: finally got camber bolts in and alignment done. Max negative camber they could achieve in the front with just the camber bolts was -1.0 on the left and -1.2 on the right. Also had the toe set as close to zero as the tech was able.
A quick blast down my favourite local road afterward (a couple of times...LOL!) confirmed that the balance and feel is better with added negative camber and the new wheels (due to wider track from the lower offset, plus lighter weight and wider rim letting the tires sit a bit better). Definitely more neutral. The reduced wheel offset also feels like it has increased the steering weight and self-centering a bit, which is good for me. Still a long way to go to get to where I want it, but it's progress! Next up may be struts and springs or coilovers, but that will be a few months away at least.
#28 | |
In any case, congrats on the wheels, they look great. |
| The Following User Says Thank You to Dzmitry For This Useful Post: | Tatsu333 (08-20-2021) |
| FS: 2017 BRZ Sport-Tech | BRZ.Omar | Canada Classifieds | 0 | 07-29-2020 04:29 PM |
| 2020 Subaru BRZ STI Sport GT CONCEPT | kev0 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 13 | 07-16-2020 07:02 PM |
| Stop Tech Sport Kit | akuhei | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 07-10-2018 09:06 PM |
| WTB: BRZ sport-tech (Canada) | AustinSedz | Cars for Sale/Trade | 2 | 11-17-2015 10:50 PM |
| FS: Black Sport-Tech BRZ (AT) | Eddie | Canada Classifieds | 0 | 06-03-2013 07:55 AM |
