Old 03-27-2021, 10:20 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
Reco for brake pads for track use?
Hi all,
I currently have Brembos with stock brake pads, but i want to get some pads that are better for the track. Any suggestions? I would prefer to have something a bit more durable than performance, if it matters (I'm still a beginner so not trying to set records or anything). Thanks.
ThaDonJsuan is offline   Reply With Quote
Old 03-31-2021, 05:43 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by ThaDonJsuan View Post
Hi all,
Probably want dedicated track pads. Not to talk down to you or anything, but as a beginner, you'll probably be fearful of highspeed corner entries and braking late so you'll probably be braking more often and eating up the pads like crazy.
Probably like HAWK HT-10, HAWK DTC-60, Ferodo, Carbotech, etc. Something that isn't a street pad or a "high performance street pad". Swap back to stock pads after you're done. I don't actually know what fits in OEM Brembo calipers, but I am sure Brembo probably carries a more aggressive pad.
Don't bother with any drilled or slotted rotors, blanks are best.
Also run dedicated track tires like Cup2s, AD08R, R888R, RS4, something a long that line (if you can afford).
Recommend upgraded brake fluid as well.
N1rve
Old 03-31-2021, 06:17 PM   #3
Grady
Grady's Avatar
Upgrade brake fluid first. I would not worry about pads until they tell you they are not up to your driving ability. More durable than performance are stock pads.
Old 04-01-2021, 07:21 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've never tried the stock PP Brembo pads at the track, they may well be OK for a few laps. But yeah, ultimately you're likely to need more track-appropriate pads and better to go in prepared. There's no one answer here as different people, even running the same lap times in the same car, can have very different requirements for feel and place very different demands on the brakes.
I've run Carbotech XP8 and XP10 on other cars and I thought they were pretty good and lasted well enough (~10-12 track days).
Currently running CSG C2 which have better bite/higher friction feel which I like. $$$ tho... They have other options as well.
You might contact the supplier with your intended usage and desires/expectations to get a recommendation.
As mentioned above, fluid is important too. I've never had any problems just running off-the-shelf parts store DOT4, no need to source more "exotic" brake fluid IMO.
Old 04-01-2021, 11:23 AM   #5
N1rve
N1rve's Avatar
Brake fluid like this? Very popular on the M cars.
https://www.amazon.com/Castrol-SRF-R.../dp/B002TM4GBQ
N1rve
Old 04-01-2021, 11:34 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
$67.58
Some people just LOVE to spend money on "special" things, whether they need it or not...
Old 04-01-2021, 02:10 PM   #7
N1rve
N1rve's Avatar
$67.58
There are some differences between this and RBF600.
SRF:
Wet boiling point is 270deg. C
Dry boiling point is 310deg. C
Motul:
Dry boiling point 594F(312C)
Wet boiling point 399F(204C).
But like SRF $70L vs RBF 600 $32L.... almost 2X the price!
N1rve
Old 04-01-2021, 02:40 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've never had a need for anything beyond this, even in a 550hp FD...
Pat (04-06-2021)
Old 04-01-2021, 03:16 PM   #9
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Running this for years. $9.85. Never Failed. The only thing I do is bleed the fluid that has been heated in the calipers out before every track day. This keeps the brake fluid in the system fresh as after a few bleeds it`s all replaced.
Old 04-01-2021, 03:42 PM   #10
CSG Mike
CSG Mike's Avatar
Hi all,
Lets get you something entry level, unless you have a big power increase and/or sticky tires.
PM me to order.
Old 04-01-2021, 04:30 PM   #11
spike021
spike021's Avatar
I'd recommend doing some research on the forums (we have a great subforum with tons of info) before just going along and buying one that someone wants you to order.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 04-06-2021, 10:20 AM   #12
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
SRF:
Motul:
RBF around me was $35+ for 500 ml last time I looked...
So I stuck with Typ200 (too bad you can't get super blue anymore)
CrowsFeast is offline   Reply With Quote
Old 04-06-2021, 12:06 PM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I still have an unopened can of the ATE superblue in my garage. I will keep it forever
Old 04-06-2021, 12:51 PM   #14
N1rve
N1rve's Avatar
On Amazon USA, it's 32 dollars for 2X 500ml for RBF600
https://www.amazon.com/dp/B07KY29SY6...ing=UTF8&psc=1
N1rve
Brake Pads for track use ThaDonJsuan BRZ First-Gen (2012+) — General Topics 8 11-15-2020 04:35 PM
Brake Pads for Track/Street Use bumperhumper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-17-2020 03:54 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
How to restore OEM brake pads after a track day? torqdork Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-24-2013 12:45 PM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 06:42 PM
