Old 03-31-2021, 02:41 AM   #1
BitusB
BitusB's Avatar
Drives: 2020 BRZ rs
Breaking in my BRZ proper
It’s official. I’m driving 5+ hours on Saturday south to a town of 7700 souls a few minutes north of the Canada/U.S. border to buy the last brand new grey manual 2020 brz rs in Western Canada. It’s been sitting in a showroom for the last 1.5 years! My questions are: should I request the dealership do anything to address the time in “storage” and aside from breaking in the engine, bedding the brakes and conditioning the paint is there anything else I should consider doing?
BitusB is offline   Reply With Quote
The Following User Says Thank You to BitusB For This Useful Post:
g e (04-02-2021)
Old 03-31-2021, 04:15 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Get insurance
Old 03-31-2021, 07:25 AM   #3
They will inspect and do the service it needs before you pick it up so there is nothing more you need to do.
You will get about 50 replies that say "ignore the break in instructions I have been breaking in bikes and cars for 1,000 years and I just drive the shit outta them right off the lot". Unless that instruction is written by the engineers that designed and built the car just ignore it and follow the instructions as listed in the owner manual.
The Following 13 Users Say Thank You to Tcoat For This Useful Post:
AJ32162 (03-31-2021), BrahmaBull1990 (04-02-2021), Capt Spaulding (03-31-2021), Dadhawk (03-31-2021), dodj (03-31-2021), Dzmitry (03-31-2021), KR-S (03-31-2021), NoHaveMSG (03-31-2021), soundman98 (03-31-2021), spcmafia (03-31-2021), spike021 (03-31-2021), Wally86 (03-31-2021), x808drifter (04-01-2021)
Old 03-31-2021, 10:11 AM   #4
AJ32162
Drives: 2019 BRZ with Performance Package
You might want to check the air pressure in the tires. Many dealers overinflate the tires to help prevent flat spots from sitting in one spot for so long. Unfortunately, some forget to deflate them during predelivery servicing. My tires were overinflated by 14 pounds.
AJ32162 is offline   Reply With Quote
The Following User Says Thank You to AJ32162 For This Useful Post:
Old 03-31-2021, 10:28 AM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Vary your RPMs while you make the drive and enjoy the first 1k miles of varying your RPMs as per the manual.
Also, congrats.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is online now   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
BrahmaBull1990 (04-02-2021), soundman98 (03-31-2021)
Old 03-31-2021, 10:36 AM   #6
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Mine sat a little over a year inside the dealership. Aside from the usual inspection and cleaning they do, I asked them to replace the battery so it's fresh - which they took care of. Break it in as the specs suggest and change your oil after and you're good to go!
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
Old 03-31-2021, 11:56 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Fill up with 91+ octane fuel as soon as possible.
Few dealers will use anything over 87. Cost, innit?
The guy trying to sell me mine was very proud of the "fact" that it runs on regular gas.
Old 03-31-2021, 12:10 PM   #8
TommyW
TommyW's Avatar
Drives: '13 Whiteout
No cruise control for 500 miles. Change oil at 500 miles, keep revs below 4,500 for 500 miles. Optimum would be break in oil for the first round.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
Old 03-31-2021, 01:05 PM   #9
extrashaky
Drives: 2014 BRZ Limited
The most important part of a break in is varying the load on the powertrain. Definitely do not use the cruise control on the return drive, and vary your speed frequently even if it annoys traffic around you.
When I got mine, I had a long drive ahead of me a couple of days later, so I took back roads through several small towns to vary up the RPM and power demands and avoid the temptation to cruise at a set engine speed. It significantly lengthened the drive, but it was worth it for a proper break in.
The Following 3 Users Say Thank You to extrashaky For This Useful Post:
Capt Spaulding (04-01-2021), Tcoat (03-31-2021), TommyW (03-31-2021)
Old 04-01-2021, 08:16 PM   #10
Grady
Grady's Avatar
I would have them change the oil. if it has sat that long and they have not replaced the battery it is probably shit and will fail you within 6 months. Follow break in procedures, not real necessary but better to be safe than sorry.
The Following User Says Thank You to Grady For This Useful Post:
BitusB (04-05-2021)
Old 04-01-2021, 10:57 PM   #11
Sasquachulator
Pavement Grey
Crowbar/tire iron + side of window
Boom, broken in.
The Following 3 Users Say Thank You to Sasquachulator For This Useful Post:
BrahmaBull1990 (04-02-2021), NoHaveMSG (04-02-2021), soundman98 (04-02-2021)
Old 04-02-2021, 09:17 AM   #12
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
This.
Call me old fashion, but I’ll gladly baby something for 1,000 miles to ensure longevity of my pricey purchase...
I just kept it under 4,000 RPM and turned on the shift light at 3k; avoid cruise control. Use the time to get to know the car’s handling.
It isn’t only the engine that needs to break-in too. Try to avoid slamming on the brakes.
After 1.5k, I had the engine oil changed and put in Motul for the gearbox and diff.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
BitusB (04-05-2021)
2020, brand new, break-in
The proper (and I mean PROPER) turn signal flasher mod for LED bulbs. catsspat Cosmetic Modification (Interior/Exterior/Lighting) 26 06-26-2019 03:03 AM
Breaking the Silence Carolina Dyno Forced Induction 79 12-15-2015 01:31 PM
Breaking-Bad SWP Build mwjcyber Member's Car Journals 7 02-17-2014 08:12 PM
Breaking Bad Season 4 tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 4 10-10-2011 08:17 PM
