Drives: 2015 Scion FR-S Raven Black
Valenti 4th Brake Light Issue
So I was rewiring the light to separate the V and the brake triangle, I did this successfully before on my car. So I was helping a buddy with his and made a dumb mistake, I attached the left black wire to the screw to the left of the node and we then tested the light and that’s when I discovered the incorrect placement. I since corrected the mistake but we are still not getting any power to the V or triangle...did I fry the board from sending power incorrectly? I circled the area in question in the picture
![]() Sent from my iPhone using Tapatalk |
#2 |
ProCrastinationConsultant
have you checked fuses?
| The Following User Says Thank You to soundman98 For This Useful Post: | Kaleb765 (03-28-2021) |
#3 |
#4 |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Are you receiving 12v, but the light doesn't turn on? Or do you not have 12v power being supplied at all? A multimeter is your best friend here, both for checking for power and checking fuses.
If you have no 12v, then as @soundman98 said check fuses. I would also suggest bench testing the light off the car first with a 12v power source/inverter. If there is 12v, then there's likely a problem with the board or connections. |
| Valenti fourth brake light install issue | spike021 | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 03-10-2022 08:26 PM |
| DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 07:17 PM |
| DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) | BirdTRD | DIY (Do-It-Yourself) Guides | 17 | 11-06-2017 09:42 PM |
| Valenti 4th brake light vs Valenti Style brake light? | JGalp | Electronics | Audio | NAV | Infotainment | 9 | 03-24-2016 06:48 PM |
| SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light | AtlasMick | Exterior Parts (Aero, Lighting, Etc.) | 8 | 03-07-2015 07:51 PM |
