| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru brz limited
Oil pressure
Before I start up my new rebuilt engine i was trying to get oil pressure going but im not getting any oil pressure the oil filter is dry i might be thinking it wrong but i dont wanna burn my starter out so any suggestion it has about 7 qts of break in oil
#2 |
Rust bucket enthusiast
How long did you crank it? Make certain you're cranking the car with the gas pedal held at 100%
You're definitely not going to burn out your starter that easily
#3 | |
Oil pressure
Not very long my concern was the starter so should i just continue cranking? Sent from my iPhone using Tapatalk |
#4 |
Yeah the starter isn't going anywhere. Should only take 10-15 seconds of cranking to see some oil pressure.
#5 |
10 secs on -> 3 mins cool-down -> ...
#6 |
Imma try and take the spark plugs out because ive been cranking for a minute still no pressure i had pressure when the engine was on stand while checking compression but had to remove oil to put in break in oil i have a oil cooler so refilling oil on stand will just have the oil coming out oil ports that connects to cooler
#7 |
Just a update i had a air pocket in oil cooler so disconnected lines cranked til i see oil coming out ports then reconnected, cranked again now i have pressure
| The Following 7 Users Say Thank You to IsaiahW For This Useful Post: | BrahmaBull1990 (03-27-2021), DarkPira7e (03-26-2021), Dzmitry (03-29-2021), jcw99 (03-27-2021), NoHaveMSG (03-26-2021), soundman98 (03-26-2021), Ultramaroon (03-26-2021) |
| Low Oil Pressure? | kimcheefists | Issues | Warranty | Recalls / TSB | 10 | 07-17-2023 04:37 AM |
| Oil Pressure | drz400dude | Engine, Exhaust, Transmission | 9 | 04-30-2019 11:32 PM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 11:27 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 05:54 PM |
| Oil Pressure.. too low? | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 65 | 08-24-2013 01:43 AM |
