Old 08-10-2019, 03:13 AM   #15
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Originally Posted by AT-JeffT View Post
Thanks for posting this. I had some very minor (but annoying) noise when reversing out of parking spots, especially if there was some incline. The bushings looked mostly fine. Only a small gap where the bushing is slotted.
Picture of worn bushing 75K miles
I replaced the bushings and while it's still early the noise/clunk seems to have gone away.
Also, for anyone trying to diagnose the same issue, I had noise when pulling away from a stop. Lastly, the sway bar did not have any up and down play, but I was able to move it horizontally, which the new bushings don't allow.
This would have been a very tricky diagnosis without the above info, thanks.
No problem, glad it helped!
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 03-21-2021, 03:38 PM   #16
p4R4d0x
Drives: 2016 Firestorm FRS
Edit: Actually it turned out to be the front strut mounts. Found some info on a TSB about it here.
I hate to bump an old thread, but I'm having exactly this issue and this was the first thread I found describing what I've been experiencing (vs bad axle or something similar). I have a Scion - does anyone happen to know if this front strut mount TSB applies to my car or if there's an equivalent Toyota one, or how I would find out? I googled similar.verbiage and Scion / Toyota but didn't pull anything up.
If not I might have to try replacing the sway bushings even though they looked ok to me - this pop is driving me crazy.
p4R4d0x is offline   Reply With Quote
The Following User Says Thank You to p4R4d0x For This Useful Post:
Capt Spaulding (03-23-2021)
Old 03-23-2021, 02:22 AM   #17
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Great.. I think I might be having a problem here as well along with contact between the end link and LCA. With it on jacks, I can forcibly move the sway bar side to side as well with an audible click sound that I thought was the endlink to LCA contact on the passenger side.
It going to be difficult to determine whether the sound is coming from the tops. I'm no inspector gadget.
Intent > Content
Old 03-23-2021, 09:09 AM   #18
Racecomp Engineering
Whiteline does have OEM sized polyurethane swaybar bushings.
- Andrew
solidONE (03-23-2021)
Old 03-23-2021, 09:18 AM   #19
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
- Andrew
I installed these a few months ago. I wasn't experiencing any issues, but I did notice the car's response in corner transitions seems more linear (at DD/street speeds).
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post:
norcalpb (04-07-2021), Racecomp Engineering (03-23-2021), solidONE (03-23-2021)
Old 03-27-2021, 11:30 PM   #20
solidONE
solidONE's Avatar
I installed some aftermarket low profile front endlinks (only slightly shorter than OEM at the shortest adjustment), and the the new markings indicating contact to the passenger LCA became even worse than with the OE endlinks. Only at a slightly different location about 1" away from the older markings.
I originally attributed this to the positioning on the LCA after installing the whiteline anti-dive/caster bushing, but now I'm not so sure since it seems like the LCA couldnt have shifted all that much at the rear bushing as it retains the same axis. Could it be due to the lateral movement of the sway bar while turning the steering wheel from my old bushings? Anyone with the popping/clicking sound have similar markings?
Edit2: clicking sound is back. will install the perrin 19mm I have laying around with some urathane bushings. If it doesnt resolve, I'll just have to wait until I can change out the shocks.
Intent > Content
Old 04-07-2021, 12:44 PM   #21
p4R4d0x
- Andrew
Thanks for the heads up! Got some, installed them.
Slight difference in steering, but... click/pop noise didn't stop, I guess it wasn't my crappy dried-out and cracked OEM sway bushings after all...
I guess... CV? I haven't had CV problems before without the car being rolling, so that would be odd to me, but I'm far from an expert.
Old 04-10-2021, 02:37 AM   #22
solidONE
solidONE's Avatar
As mentioned in earlier posts, possibly this, maybe: https://subaru.oemdtc.com/333/poppin...12-2016-subaru
do you see similar markings from contact on either of the LCA?
Intent > Content
Old 04-20-2021, 04:14 PM   #23
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Just wanted to say I had the same problem. Doing track days in the Louisiana sun, the bushings actually melted and looked exactly like that on side the exhaust runs through. No problems on the opposite side. I replaced with Whiteline bushings and it melted again. Replaced a second time and heat wrapped the pipe. They still melt but at a much slower rate now!
B T is offline   Reply With Quote
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
SOLD Cusco Sway Bars Front & Rear 20mm 16mm Bushing Swaybar Swaybars hirollaz Brakes, Suspension, Chassis 6 06-01-2015 06:30 PM
Whiteline Front and Rear Sway Bar + Bushing Kit $550 MicheleAbbate Brakes, Suspension, Chassis 1 01-28-2015 11:23 AM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
3M tape failing on front lip after time? 1Cor10:23 Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2013 01:51 AM
