| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Country Boy 4 Life
Yes, the 17x8 +42 clears stock brakes. The 17x9 +35 clears PP Brembos.
I LIKE TIRES! |
#16 |
#17 |
Country Boy 4 Life
Yes, both sizes easily. And the OEM spring perch too.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | stlgrym3 (09-17-2019) |
#18 |
Drives: Mr.Happy
Hey guys, as i'm going to get the 17x8 +42 for my performance package, anyone could advise that it will fit over the Brembo?
#19 | |
Drives: 24 GR Yaris, 23 GR86
This thread might help you. From my experience they do need 3mm spacer to fit over 1H5.6005A Brembo kit which is supposed to be a little wider than PP Brembo caliper - technicaly they do fit without spacer but its probably just 1mm of clearance. In worst case scenario you can throw in a 3mm slip on spacer and you should be fine. Last edited by MrSkubi; 03-18-2021 at 03:14 AM. |
| The Following User Says Thank You to MrSkubi For This Useful Post: | timurrrr (03-18-2021) |
| Tags |
| tc105x, wedssport, wedssports |
| New Season - New Wheels Enkei TS5, WedsSport TC105X, RAYS G025 | eMCee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 05-28-2020 07:41 PM |
| WedsSport TC105X 17x9 +35 and TRD Springs | JeffFAFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 01-10-2020 08:46 AM |
| Wheel Directory: WedsSport TC105N 17x8.0 +42 | Draco-REX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 94 | 06-21-2019 04:33 AM |
| Wheel Directory: WedsSport SA-60 17x8.0 +45 | jdzumwalt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 12-27-2013 02:49 PM |
| Wheel Directory: WedsSport TC105N 17x8.0 +42 / 17x9.0 +35 | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 56 | 03-08-2013 12:10 PM |
