Old 03-21-2021, 06:56 AM   #1
Biggumzzz
Drives: Toyota 86 2014 GTS
2nd to 3rd gear weird over-rev jerk when shifting
So my car has recently started playing up with the gears. It’s an AUTO. It does the problem in D and in M as well. The problem only happens in 2nd to 3rd. Every other gear is full power and shifts smooth like butter. 2nd is very sputtery weirdly enough. Engine sometimes backfires as I accelerate during this gear. And when I shift at 6000 - 7000 rpm, the car jerks and you can hear the car try to rev harder during it mid shift, like a launch almost. What’s the problem? Any idea? Thankyou hopefully the video shows you guys something. The rpm needle bounces before it even hits max rpm. Never does it on cold. Only ever warm. The car also has loss of power during the 2nd gear.
Biggumzzz is offline   Reply With Quote
Old 03-21-2021, 07:00 AM   #2
Biggumzzz
It’s getting worse. The car launches forward, it jerks a shit tonne during the 2nd to 3rd shift
Old 03-21-2021, 07:49 AM   #3
radroach
Drives: car
That's called a flare shift and it's bad for the transmission.
Have you tried letting off a bit between shifts? I don't own an auto 86 but on all my other automatic-transmission cars I always lift a little bit between shifts unless I'm going full-throttle.
Did a quick google search and it seems its been a complaint for some owners for awhile.
Old 03-21-2021, 09:38 AM   #4
Ashikabi
Ashikabi's Avatar
You stock or tuned?
Sent from my ONEPLUS A5010 using Tapatalk
Old 03-21-2021, 09:59 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
what's your mileage, and have you checked the fluid level?
Old 03-21-2021, 11:01 AM   #6
Biggumzzz
My car was just serviced for 90,000km. All fluids and filters were changed. The problem was happening before the service. I was hoping it would fix itself with new transmission fluid. But nope. And letting off the throttle it’s still happening. It revs highly for a second and jerks like crazy
Old 03-21-2021, 11:01 AM   #7
Biggumzzz
You stock or tuned?
Stock everything except exhaust
Old 03-21-2021, 11:22 AM   #8
Ashikabi
Ashikabi's Avatar
Hmm yeah that's weird. If you were tuned, I'd say look into that. But since you're not, then you're kinda out of my expertise on this one
Old 03-21-2021, 11:24 AM   #9
Biggumzzz
How much would it be to fix do you know?
Old 03-21-2021, 08:27 PM   #10
czellers
czellers's Avatar
Drives: 2K19 GT86
Have you tried disconnecting the battery completely (both +/- terminals) for a few mins, then testing again?
czellers is offline   Reply With Quote
Old 03-22-2021, 06:35 AM   #11
Biggumzzz
I’ve tried everything. It feels mechanically related. Not ecu or anything
Old 03-22-2021, 06:16 PM   #12
radroach
Drives: car
@Biggumzzz maybe your transmission mount is worn out
Old 03-22-2021, 09:05 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
"All fluids and filters were changed" .. but does that list included AT gearbox oil? On many modern cars manufacturers mark that it's not needed and that it's for lifetime .. so "all" by official regular maintenance procedures may had omited that.
Also in some cases flushing/filling procedure matters to be performed in right way with right steps taken.
Mine, as all the other cars i've driven, is MT, so i cannot chime in with other advices from own experience but these generic ones.
bcj (03-23-2021), Ultramaroon (03-22-2021)
Old 03-23-2021, 08:21 AM   #14
Biggumzzz
Yes at fluid changed. Said on service
Weird Growling sound when high rpm shifting Blackedout86 Engine, Exhaust, Transmission 1 07-25-2020 09:28 AM
Slow RPM Buildup and weird shifting sound Blackedout86 Engine, Exhaust, Transmission 17 07-25-2020 08:27 AM
Weird shifting? Maybe? Please tell me I am wrong. treerexaudi Official Issues | Warranty | Recalls / TSB 27 04-02-2019 03:23 PM
Gear shifting TexasFRS Scion FR-S / Toyota 86 GT86 General Forum 31 05-11-2016 10:29 PM
Shifting from 1st-2nd gear... FRSpappa Engine, Exhaust, Transmission 13 05-24-2014 10:06 PM
