Old 03-19-2021, 02:48 AM   #15
Originally Posted by smg1138 View Post
What's 37 Nm in 'Murican?
https://bfy.tw/QZfW
Old 03-19-2021, 02:54 AM   #16
gpvecchi
gpvecchi's Avatar
Grab the tip of the fork and pull it forward. Don't talk about it. Do it. It should be crystal clear that nudging the position of the slave cylinder does absolutely nothing. The whole system still comes to rest with the TOB just touching the pressure plate.
You aren't removing any play. It's not there at all.
You still don't understand how the slave cylinder works...
Study a little, then we can talk again.
BTW, I work on cars since 15 years.
Old 03-19-2021, 03:09 AM   #17
Originally Posted by gpvecchi View Post
For sure you can move it if your not pressing the pedal, the circuit is open to the reservoir till you press it!
And you still don't see the connection?
Old 03-19-2021, 03:51 AM   #18
gpvecchi
gpvecchi's Avatar
Not interested in bringing on this discussion...
Old 03-19-2021, 10:40 AM   #19
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I am.
Dzmitry is offline   Reply With Quote
Old 03-19-2021, 12:00 PM   #20
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I may or may not give this a try. That said, the explanation for how/why it might work is unsatisfying. It's a bit like saying I can change the the operation of disc brakes (another self adjusting system) by raising the car and pushing on the calipers with the heel of my hand.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 03-19-2021, 01:00 PM   #21
Perfect analogy.
Clutch pedal making weird noises Jonatanv98 Engine, Exhaust, Transmission 1 11-10-2020 10:16 PM
Weird sound when throttling after foot is off the pedal VincentN Issues | Warranty | Recalls / TSB 7 10-23-2017 12:16 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 07:04 PM
I'm feeling scared for my clutch xITSxTHExPOPEx Scion FR-S / Toyota 86 GT86 General Forum 15 05-16-2014 08:21 PM
