Old 03-06-2021, 04:14 AM   #1
Arvin
Drives: Subaru BRZ 2016 auto
Subaru BRZ won’t start on p gear help
Hello guys I hope you all well and enjoying
I have few problems with my BRZ 2016
Premium model auto
Which got few dash Errors
Engine light, abs, and traction control
And it doesn’t start on the gear p but will start on the gear neutral with few times try
And I also find out there is a sensors attached to the axle got some damage
The part number is B155444-1 with this 611512 number on top of the other number
If anyone knows what’s this sensor for ?
Would be a big help
However I google a lot to find this part by searching part number I couldn’t find it
Arvin is offline   Reply With Quote
Old 03-06-2021, 08:39 AM   #2
Alphaw0lf666
Drives: 50th anniversary BRZ
I would get the codes scanned and check them first. I would imagine the sensor might be a wheel speed sensor. Check this thread out.
https://r.tapatalk.com/shareLink/top...ink_source=app
On mobile so apologies for the url format.
Also welcome to the forum!
Sent from my SM-G960U using Tapatalk
Alphaw0lf666 is offline   Reply With Quote
The Following User Says Thank You to Alphaw0lf666 For This Useful Post:
Ultramaroon (03-18-2021)
Old 03-06-2021, 10:50 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
sounds like your shift interlock could be out of adjustment. but the more important question is how the sensors got damaged in the first place, as none of the sensors on this car are in an area they're easy to knock around-- i suspect there's other damage.
Old 03-06-2021, 10:56 PM   #4
Arvin
Hello mate
Thanks for sharing the link it might be a good help for the other gay as well as I am sure about 70 percent that the problems coming from that stupid sensor
My car had small rear damage and I tow the car to home to fix it but because of the car got too low body the truck driver slide the car on the back of truck as he didn’t have experience to towing to coupe cars that’s way the sensor got looose
I believe
And also thanks for welcoming and I am really appreciate to be here with you guys
Old 03-07-2021, 04:10 AM   #5
Arvin
Thanks for the reply yeah the car had light
rear crash and the sensor that I am talking about was got loose while transporting I guess
I have checked it wasn’t wheels speed sensor
Old 03-17-2021, 04:46 AM   #6
Arvin
Hi guys I fixed the sensor and I don’t have the errors in dash any more but I still have problems with starting the car
It won’t start on the P gear it will but very rarely
But will start on the gear neutral
Please any help and recommendations
Thanks
Old 03-17-2021, 05:58 PM   #7
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Hi, no one has come up with an idea, so best to find a garage/dealer for them to look
at it.
Good luck.
CB750F is offline   Reply With Quote
Old 03-17-2021, 06:49 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Sounds like the park/neutral position switch.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (03-18-2021), Ultramaroon (03-18-2021)
Old 03-18-2021, 09:48 AM   #9
Arvin
Hi thanks for the response
What’s that means ?
Any checking recommendations ?
Old 03-18-2021, 01:03 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What’s that means ?
Thankfully for everyone on the boards @Ultramaroon has the repair manuals linked in his sig.
https://demos.starbase7.net/t3Portal..._rm_index.html
Go to "Drivetrain", "TX6A Automatic Transmission", and "Park/Neutral Position Switch".
I'd skip the on vehicle inspection, you have pretty much already done that. The "component" section shows you what the part is and where it is mounted. I would give it and the wiring harness a good inspection, pull the connector apart and make sure there is no damage. Then try the inspection procedure, if it checks out good reinstall and go through the adjustment procedure.
bcj (03-18-2021), Ultramaroon (03-18-2021)
Old 04-02-2021, 09:22 AM   #11
Arvin
Hi guys thanks for your help and recommendations
I actually find out the problem of my car
It was coming from one of the relay I think the main starter relay
However I change few of them then now it’s starting and all the errors been gone now I am very happy guys and really appreciate your help and recommendations
The Following User Says Thank You to Arvin For This Useful Post:
BrahmaBull1990 (04-05-2021)
2nd gear cold start problem eddwvrd Issues | Warranty | Recalls / TSB 29 07-23-2018 05:21 PM
Subaru BRZ with Proximity Key Fails to Start eprosenx Issues | Warranty | Recalls / TSB 36 02-11-2016 12:15 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Anyone who works at Subaru, GL-3 Gear Oil? Jeff Lange Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 12-11-2012 05:09 PM
On the road: Subaru’s new BRZ (Top Gear) Mr Franky BRZ First-Gen (2012+) — General Topics 4 03-29-2012 08:58 AM
