Old 02-01-2018, 02:01 PM   #1
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I made an E85 circuit with display...
I put together an E85 circuit with display.
[ame="https://www.youtube.com/watch?v=yl5X_WG8wKw"]Flex sensor control test - YouTube[/ame]
I have modified the coding to provide either a .5 for 0% or 4.5 for 100% ethanol content.
It's pretty simple.
This is code for 0% at .5
expectedv = ((((HZ-50.0)*0.01)*4)+0.5);
This is the code for 100% at 4.5
expectedv = ((((HZ-50.0)*0.01)*-4)+4.5);
Jaden
Jaden is offline   Reply With Quote
Old 02-01-2018, 05:33 PM   #2
cavell
Drives: 86
cavell is offline   Reply With Quote
Old 02-01-2018, 08:18 PM   #3
Jaden
Road-hole
This is a different setup and programming than ztan's...
Originally Posted by cavell View Post
..thanks to ztan ..also managed a display with his double tap traction switch..been using it for 2 years now.. ����
Yeah this is a different setup and programming than ztan's.
I read through that entire thread and didn't really see anything for an integrated display. It's a long thread so maybe I missed it without realizing it or it was a non integrated solution.
Anyways, I set this one up and it's working so whatever. Of course Zeke's work on the coding of the bin for flex fuel is astounding and makes these a much more worthwhile endeavor. Hell, that's why I added the code to be able to read 100% ethanol at 4.5v...
Jaden
Old 02-02-2018, 02:19 AM   #4
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
This is cool. I'm actually developing a continuation of robot's clock replacement work.
I've fixed all of the major issues it had with display and warning states, and incorporated ztan's work for ethanol content, added mapping for a ProSport pressure sender to display oil pressure, and added a simple clock. In theory, it should work right now but I'm deployed until May.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 02-02-2018, 06:49 AM   #5
steve99
Drives: FT86
Nice work
Old 02-05-2018, 05:50 PM   #6
Jaden
Road-hole
Here it is working in the car...
Yeah, so I did a couple of things.
I verified everything was good and heat shrinked the arduino nano and sealed it in a case. Then I ran the harness to it and verified everything was working properly in the car.
Then I took an old plastic cd drive cover from a computer case and cut out a section for the lcd to fit.
After fitting everything I put it in and verified it all worked.
I have a plug and play harness to tie it into the ECU once I get the flex fuel bin.
I still have to figure out how I will mount the lcd plate permanently, it's just electrical taped on right now.
Jaden
Old 03-13-2021, 10:59 AM   #7
Jaden
Road-hole
I've since 3d printed a display plate...
I've since 3d printed an exact fit display board plate that pressure fits into that coin holder.
Jaden
Old 03-13-2021, 01:58 PM   #8
86TOYO2k17
Drives: 2017 toyota 86
Jaden
Ok, this is a bit different than I imagined when you said you made an E85 kit. You actually made one not pieced it together. Pretty cool.
Old 03-15-2021, 02:04 AM   #9
Jaden
Road-hole
Thought I'd throw up a pic.
Here's a pic of what it looks like with the 3d printed display case. The filament I had used got some funky white streaking in it, but whatever, I may, if I get around to it, reprint it in carbon fiber reinforced polycarbonate, that seems to turn out the best.
Jaden
CA-FI Heads Up Display XtremeMaC Electronics | Audio | NAV | Infotainment 3 08-18-2015 08:41 AM
WTB flux2 display FJ/BRZ Canada Classifieds 0 06-12-2014 01:26 AM
mpg display vs l/100km mckendym Scion FR-S / Toyota 86 GT86 General Forum 1 05-17-2013 09:15 AM
Mpg display Dipstik-sportech BRZ First-Gen (2012+) — General Topics 18 11-26-2012 07:38 AM
Whiteout FR-S Display Car Jeff Lange Member's Car Journals 24 09-19-2012 02:53 AM
