Old 03-14-2021, 11:24 PM   #1
dpfarr
Drives: BRZ ts
Stuck Wilwood Pistons
When I went to rebuild my calipers and blow the pistons out of the calipers a couple wouldn’t come out. Most come out but a few don’t budge.
I have a couple thoughts.
1) hit them with a heat gun to help liberate them and then hit them with air.
2) a solvent to break down crud and old seals.
3) insert a rubber stopper I can compress with a nut and bolt and then apply some torque to liberate them.
4) breakdown the calipers via side bolts and some combination of #1&3
dpfarr is offline   Reply With Quote
Old 03-14-2021, 11:38 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Put the other pistons back in just a little bit and use a clamp to keep them there. Then use compressed air.
The Following 4 Users Say Thank You to Pat For This Useful Post:
CSG Mike (03-15-2021), dpfarr (03-15-2021), ls1ac (03-15-2021), Tcoat (03-15-2021)
Old 03-15-2021, 10:13 AM   #3
ls1ac
ls1ac's Avatar
If these are track calipers then there is no dust shield and should be serviced regularly.
The dust shield keeps water and dirt out of the pistons.
Pat is right on, use a clamp on the good ones, holding the good ones in place and use air and WD 40.
You should be able to move the pistons back in and out a little several times to get the lub in there. The build up of dirt or corrosion should come loose. Unless that piston has not been working at all.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
Old 03-15-2021, 11:31 AM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Then hit the outside of the pistons really well with a green Scotch Brite pad.
The Following User Says Thank You to Pat For This Useful Post:
dpfarr (03-15-2021)
Old 03-15-2021, 11:51 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Calipers with square o-rings by chance? If so you will want to split the bodys and use a combination of compressed air and some kind of inside puller like your rubber stopper idea. Rock the piston while you put air pressure to it. What I tend to see with Wilwood calipers with square orings is if the caliper body gets deflection it shears the corner of the oring and it gets bound between the piston and the body causing the issue you are having. Don’t think heat is going to help.
dpfarr (03-15-2021)
Old 03-15-2021, 09:15 PM   #6
dpfarr
Drives: BRZ ts
Yea, square rings.
In regards to the clamp, I feel like using a thicker wood block between the pistons that move and a thinner one where they’re not is equivalent?
Is using wd40 inside calipers body not a big deal? I’m probably going to get them powder coated again anyways so I guess hitting them with brake cleaner after using wd40 would be doable.
Old 03-15-2021, 09:45 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
A wood block should work just fine as long as it is precisely the right thickness.
Old 03-15-2021, 09:46 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by dpfarr View Post
Yea, square rings.
You are replacing the orings anyway, WD isn’t going to hurt anything else. Check the piston bores for burs before you put new ones in.
Using the thick/thin wood block like that should work. Watch your fingers, those things are going to come out at Mach 10.
Old 03-16-2021, 02:56 PM   #9
ls1ac
ls1ac's Avatar
The problem with a wood block is that the opposing piston will come out. If it is a 4 piston then you can use the block for two but the one opposing the stuck one will pop out.
The Following User Says Thank You to ls1ac For This Useful Post:
dpfarr (03-17-2021)
RR racing BBK - 4 pistons Lorico Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-31-2017 02:55 AM
Wilwood 2 Piece aluminum hat front BBK 6 Pistons Kazuya Canada Classifieds 13 01-22-2016 10:39 PM
13.5:1 Pistons woode Forced Induction 13 04-27-2014 11:06 PM
CP Pistons for FA20 MattR Engine, Exhaust, Transmission 1 10-04-2012 07:22 PM
