Old 03-11-2021, 06:10 PM   #1
paintdude258
paintdude258's Avatar
How to stop 18x9.5 RPF1 Rubbing front fender liner at full lock
I am currently running a squared set of 18x9.5 +38 RPF1s on my BRZ. I am running KWV3 coils, around 1.5 degrees of camber, and firehawk indy 500 255/35/18 tires.
At full lock, my tires rub the fender liners, causing them to get ripped out every few thousand miles.
I also have tie rod ends that allow a few extra degrees of steering angle.
What are my options to stop this from happening?
I would definitely consider buying two extra wheels with different offsets or widths if that would solve it.
I would also consider downsizing width or height all together if thats the best option.
Any and all feedback greatly welcomed.
Thanks guys and gals,
Blake
paintdude258 is offline   Reply With Quote
Old 03-11-2021, 06:46 PM   #2
Grady
Grady's Avatar
Steering rack limiters.
The Following User Says Thank You to Grady For This Useful Post:
paintdude258 (03-12-2021)
Old 03-11-2021, 07:06 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Moar camber?
What size tires? if 255s, go to 245s which are both narrower and shorter
Old 03-11-2021, 09:17 PM   #4
whataboutbob
AutoX-10/10ths every run
Extended studs and spacers (and lots of - camber) helped me run 295/35R17 Hoosier A7s square on 17x9.5et45 wheels.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 03-11-2021, 10:06 PM   #5
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I am running 18x9.5 +36 on 245/35-18s with RCE SS-1 (KW shock so very similar to yours) and -2.7 camber up front. I don't rub on the fender liners at all. I am pretty sure you can get 255s on similar specs and not rub, too. The only thing I could think of is maybe add some more camber.
What part of your tire is rubbing?
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Old 03-12-2021, 01:54 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
sounds like you need duct tape deathmatch training.
Old 03-12-2021, 11:16 AM   #7
paintdude258
Originally Posted by ZDan View Post
Moar camber?
255/35/18, yessir. Will 245s fit on a 18x9.5 wheel?
Originally Posted by whataboutbob View Post
Extended studs and spacers (and lots of - camber) helped me run 295/35R17 Hoosier A7s square on 17x95et45 wheels.
For how many times I have taken the wheels off, its a miracle I haven't broken a stud. Only problem with this approach is that my tires are already flush with the fender, I dont know If i could add a spacer and not have the tire poke out.
Hmmm, its the front side of the tire, presumably the front right side of the tire that is touching. I am assuming this based on what part of the fender liner is getting ripped out. Not unlikely that its also the back right side of the tire, but this part of the fender liner appears to be much less susceptible to wear. Love the RCEs, they were a bit out of my price range after getting a hella deal on the KWs
Old 03-12-2021, 11:34 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yup, 245/35/18 fits on 8" - 9.5". Unfortunately not many 200tw "Extreme Performance" tires in that size though. If you're planning on tracking it you should go 225s on 17x8 or 245 on 17x9 IMO
https://www.tirerack.com/tires/tires...omCompare1=yes
Yup, you need *camber*. Unfortunately if you are on stock struts and spring diameters, you won't be able to get much if any with camber bolts with 9.5" +38 wheels. Camber plates will get you plenty, but be aware some of them rob you of bump travel if you are running lower than stock. Offset top mounts (Pedders?) + camber bolts *might* get you there.
paintdude258 (03-23-2021)
Old 03-12-2021, 12:42 PM   #9
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Agreed with the above that more camber sounds like your best solution with the bonus of handling improvement. If you're not tracking or doing much twisty's, then maybe a downsized tire is the better option.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
WTB: VTA Catch Can & front right fender liner lcoopman Want-To-Buy Requests 0 05-23-2019 01:35 PM
Tire Rubbing Fender Liner Help Pizzachicken Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-04-2018 10:59 AM
17x9 +45 rubbing fender liner with coilovers nomis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-13-2016 01:41 AM
WTB: Raven front bumper plus front underpanel and passenger side front fender liner THEmailman Want-To-Buy Requests 1 04-20-2014 01:05 AM
WTB: FRONT FENDER LINER mr. slim Want-To-Buy Requests 0 01-06-2014 06:05 PM
