| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Subaru BRZ 2016 auto
Subaru BRZ won’t start on p gear help
Hello guys I hope you all well and enjoying
I have few problems with my BRZ 2016 Premium model auto Which got few dash Errors Engine light, abs, and traction control And it doesn’t start on the gear p but will start on the gear neutral with few times try And I also find out there is a sensors attached to the axle got some damage The part number is B155444-1 with this 611512 number on top of the other number If anyone knows what’s this sensor for ? Would be a big help However I google a lot to find this part by searching part number I couldn’t find it |
#2 |
Drives: 50th anniversary BRZ
I would get the codes scanned and check them first. I would imagine the sensor might be a wheel speed sensor. Check this thread out.
https://r.tapatalk.com/shareLink/top...ink_source=app On mobile so apologies for the url format. Also welcome to the forum! Sent from my SM-G960U using Tapatalk |
| The Following User Says Thank You to Alphaw0lf666 For This Useful Post: | Ultramaroon (03-18-2021) |
#3 |
ProCrastinationConsultant
sounds like your shift interlock could be out of adjustment. but the more important question is how the sensors got damaged in the first place, as none of the sensors on this car are in an area they're easy to knock around-- i suspect there's other damage.
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (03-18-2021) |
#4 | |
Thanks for sharing the link it might be a good help for the other gay as well as I am sure about 70 percent that the problems coming from that stupid sensor My car had small rear damage and I tow the car to home to fix it but because of the car got too low body the truck driver slide the car on the back of truck as he didn’t have experience to towing to coupe cars that’s way the sensor got looose I believe And also thanks for welcoming and I am really appreciate to be here with you guys |
#5 | |
rear crash and the sensor that I am talking about was got loose while transporting I guess I have checked it wasn’t wheels speed sensor |
#6 |
Hi guys I fixed the sensor and I don’t have the errors in dash any more but I still have problems with starting the car
It won’t start on the P gear it will but very rarely But will start on the gear neutral Please any help and recommendations Thanks |
#7 |
Drives: 2015 BRZ WRB
Hi, no one has come up with an idea, so best to find a garage/dealer for them to look
at it. Good luck. |
#8 |
Drives: Crapcan
Sounds like the park/neutral position switch.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (03-18-2021), Ultramaroon (03-18-2021) |
#9 |
#10 | |
Drives: Crapcan
https://demos.starbase7.net/t3Portal..._rm_index.html Go to "Drivetrain", "TX6A Automatic Transmission", and "Park/Neutral Position Switch". I'd skip the on vehicle inspection, you have pretty much already done that. The "component" section shows you what the part is and where it is mounted. I would give it and the wiring harness a good inspection, pull the connector apart and make sure there is no damage. Then try the inspection procedure, if it checks out good reinstall and go through the adjustment procedure.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | bcj (03-18-2021), Ultramaroon (03-18-2021) |
#11 |
Hi guys thanks for your help and recommendations
I actually find out the problem of my car It was coming from one of the relay I think the main starter relay However I change few of them then now it’s starting and all the errors been gone now I am very happy guys and really appreciate your help and recommendations |
| The Following User Says Thank You to Arvin For This Useful Post: | BrahmaBull1990 (04-05-2021) |
| 2nd gear cold start problem | eddwvrd | Issues | Warranty | Recalls / TSB | 29 | 07-23-2018 05:21 PM |
| Subaru BRZ with Proximity Key Fails to Start | eprosenx | Issues | Warranty | Recalls / TSB | 36 | 02-11-2016 12:15 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 07:06 PM |
| Anyone who works at Subaru, GL-3 Gear Oil? | Jeff Lange | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 12-11-2012 05:09 PM |
| On the road: Subaru’s new BRZ (Top Gear) | Mr Franky | BRZ First-Gen (2012+) — General Topics | 4 | 03-29-2012 08:58 AM |
