#15 | |
I'd give it about a 8-10hp bump over stock. It's noticeable, a little more direct but really shines at higher rpms. I will be getting a dyno with the FA20Club header and unichip tune. It's not the cheapest option but I'm happy with it. The only other CAI's I'd consider are the Vigilant, FA20Club.com, or Perrin. Just my view.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#16 |
Those pics are generic and what you get when using a place like them. They have it mislabeled and misrepresented.
We have these on hand, did a review and have real pics. http://www.ft86club.com/forums/showthread.php?t=24884 |
#17 |
My bad, I meant FT-86 SpeedFactory ^ is where I got mine.
| The Following User Says Thank You to swift996 For This Useful Post: | FT-86 SpeedFactory (04-13-2013) |
#18 | |
Someone already blew parts of their spark plug tips off, I wouldn't even consider this intake without a proper dyno tune. Just my .02..... |
#19 |
Driving Enthusiast
Drives: 2013 BRZ Limited
Ive got one installed on my BRZ.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.My BRZ |
#20 |
The AEM MAF Module doesn't really trick anything.
When the intake tubing diameter is increased to take advantage of the higher flowing capability of the open element air filter, there needs to be a plan to correct the MAF sensor reading otherwise there is possible check engine light ensues. The ETI re-conditions much of the sensor noise not correctible by other means such as a venturi or a “neck down” MAF housing and AEM strongly believe's this is the best strategy to provide the most consistent/accurate air flow readings to the ECU so no CEL is issued. |
| The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post: | Hyper4mance2k (04-23-2015), jwjknorr (04-13-2013) |
#21 | |
Drives: 2017 BRZ WRB with golden wheels
I just purchased the AEM CAI that you show on your post and was hopping that you can answer a question about it... AEM says that no Tune is required, is this true? can I just install it and use the stock tune? thanks in advance! |
| The Following User Says Thank You to alvarompl For This Useful Post: | JesseG (03-03-2021) |
#22 | |
Señor Member
![]() You must have done some searching to have found an 8 year old thread, the short answer is it will work fine without a tune but will be better with one. Just FYI most intakes on this platform don't really add any power as the stock system is pretty well designed. It will add some nice induction noise tho.
1974 TA22 Celica
2013 86 GT |
#23 | |
Drives: 2K19 GT86
#24 |
Drives: 2K19 GT86
Also, here's a link to the thread where I installed the skunk2 powerbox with pictures (only like 250 on 86speed[dot]com)
https://www.ft86club.com/forums/showthread.php?t=144263 Really nice quality and has a removable restrictor for custom tune situations. I'll be getting a custom tune/MAF rescale soon. |
#25 | |
I am also planning on getting a OFT next week I thought it might help with some gains in HP. thanks for the help! |
| The Following User Says Thank You to alvarompl For This Useful Post: | Turdinator (03-03-2021) |
#26 | |
Drives: 17 Asphalt 86
OFT does their tuning with it. Get a high flow filter. |
#27 | |
Drives: 2016 Scion FR-S
AEM Cold Air Intake
Depending on your goals, you might want to take a look at the TRD intake also. I have one and it made a nice difference in the induction sound. Which was basically zero with the stock intake. The nice thing about the TRD intake is it’s set up exactly like the stock airbox, so you have the same safety as the factory setup. You can also pair it with the HKS air scoop. The downside is cost unfortunately. Also, make sure to do the sound tube delete. If you are looking for power, a CAI and proper tune would be the way to go. But like others have said you don’t need the tune. The stock intake is really efficient and is set up in a great location, so the biggest gain IMO is the induction sound. ![]() ![]() Duh, you have a BRZ, you won’t want a Toyota part, never mind! But there might be an equivalent Subaru part. Sent from my iPhone using Tapatalk |
#28 |
Thanks Everyone!! I appreciate the advice! makes more sense now and have a better understanding of what I'm doing.
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| cold air intake? | carbonBLUE | Engine, Exhaust, Transmission | 72 | 09-30-2013 12:56 PM |
| AEM Cold Air Intake? 41-1408DS | JeremyClarkson | Engine, Exhaust, Transmission | 6 | 04-05-2013 12:32 AM |
| Perrin cold air intake | Tyson | Engine, Exhaust, Transmission | 5 | 02-15-2013 12:06 PM |
| FRS AEM Cold Air Intake | KenAEM | Engine, Exhaust, Transmission | 28 | 10-24-2012 12:48 PM |
