Old 02-26-2021, 12:52 AM   #1
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Top hats for stock Ts shocks
I was wondering if you can get top hats with camber adjustment for stock Ts brz shocks
Old 02-26-2021, 03:50 AM   #2
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Raceseng makes nice top hats
MrSkubi is offline   Reply With Quote
Old 02-26-2021, 09:06 AM   #3
Racecomp Engineering
They make great top hats, but I don't recommend them for stock shocks.
How much camber do you want to run? What kind and what size wheels + tires do you run and will that change in the future?
- Andrew
Decep (02-27-2021), wparsons (03-04-2021)
Old 02-26-2021, 01:44 PM   #4
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
- Andrew
I`m wanting to get more than I have -1.5 with camber bolts. I have 2 wheel sets 18 x 8 +48 with 235 Re003/?500 tires street and wet track use, 17 x 8 +50 with 225 Nt01 for track (1/8+/4mm clearence).
I was going to wear out the stock ts shocks and replace with some Bilsteins and some top hats if possible.
Old 02-26-2021, 05:02 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
On my car, Raceseng plates plus 1.2" lowering springs resulted in bottoming of the stock struts. They work great with same setup with Bilsteins though! What's your ride height?
gen3v8 (02-26-2021)
Old 02-26-2021, 06:20 PM   #6
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
I have the standard Sti pink springs
Old 02-27-2021, 08:46 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should be OK, but camber plates will take away some bump travel so be aware of that. Bilsteins have a lot more bump travel so even at -1.25" ride height I'm OK now. With stock struts the ride was horrendous, front struts would bottom out with a big bang over the *smallest* bumps!
gen3v8 (03-08-2021)
Old 02-27-2021, 10:25 AM   #8
You could consider the Pedders OEM style top mounts, which would be easy but you'd probably want more for the track. No change in ride height or bump travel.
Not all camber plates take away bump travel...if they mount on top of the OEM spring perch you're okay but most will usually raise ride height slightly.
I'm not sure what's easily available for you in Australia, but Pedders, Cusco, and Beatrush have camber plate options. Of those I would probably choose the Beatrush as I generally don't like the generic flat camber plates and worry about them bending (it happens). They'll all raise ride height though (no change in bump travel).
We have an option that actually lowers the car and does not remove bump travel, but they're backordered and we're on the other side of the world.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
gen3v8 (02-27-2021), wparsons (03-04-2021), ZDan (02-27-2021)
Old 03-08-2021, 01:09 PM   #9
Koba
Drives: 2020 BRZ
Why not? Just curios. Thanks!
Koba is offline   Reply With Quote
Old 03-08-2021, 04:10 PM   #10
Their design replaces the OEM upper spring perch with their own design, which is neat but it reduces compression travel when used on stock style struts.
- Andrew
gen3v8 (03-08-2021), Thefalls (03-09-2021)
FS: OEM FR-S struts & shocks w/ top hats, springs, and front end links indafastln Brakes, Suspension, Chassis 0 05-16-2017 02:13 PM
WTB: OEM/stock suspension assembly (springs, shocks, top hats) f0rge Canada Classifieds 4 12-07-2015 05:45 PM
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 08:31 AM
FRS stock wheels (no tmps) and shocks (with top hats) in 626 JeffTing Southern California 0 07-06-2014 01:30 AM
