| Racecomp Engineering |
02-27-2021 10:25 AM |
Originally Posted by gen3v8
(Post 3409697)
I`m wanting to get more than I have -1.5 with camber bolts. I have 2 wheel sets 18 x 8 +48 with 235 Re003/?500 tires street and wet track use, 17 x 8 +50 with 225 Nt01 for track (1/8+/4mm clearence).
I was going to wear out the stock ts shocks and replace with some Bilsteins and some top hats if possible.
You could consider the Pedders OEM style top mounts, which would be easy but you'd probably want more for the track. No change in ride height or bump travel.
Not all camber plates take away bump travel...if they mount on top of the OEM spring perch you're okay but most will usually raise ride height slightly.
I'm not sure what's easily available for you in Australia, but Pedders, Cusco, and Beatrush have camber plate options. Of those I would probably choose the Beatrush as I generally don't like the generic flat camber plates and worry about them bending (it happens). They'll all raise ride height though (no change in bump travel).
We have an option that actually lowers the car and does not remove bump travel, but they're backordered and we're on the other side of the world.
- Andrew
