| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 |
Drives: White Toyota 86
Has anyone else tried the Pennzoil sychromesh besides rice_classic? Any reviews? Not that I dont trust them but I like the to have a sample size of more than just one, and when I google/search it shows posts from them from 2012 running the same fluid, so I guess thats a good thing XD.
#44 |
Drives: 2017 PP BRZ
Another for Redline. I had issues upshifting from first into second gear and downshifting from fifth into fourth gear. Ever since I switched to redline, I have had zero issues.
#45 |
Drives: '16 BRZ
Redline or Motul, which ever is available or on sale.
| The Following User Says Thank You to wil5bart For This Useful Post: | jeepmor (03-02-2021) |
#46 |
Drives: 2017 PP BRZ
I switched to the CounterSpace garage secret sauce 50:50 mix.
#47 | |
Howdy
Drives: 2020 BRZ PP
Was literally just looking for it on CSG. I think motul is too much for the PNW weather. It takes forever to heat up
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#48 |
Drives: 2017 PP BRZ
| The Following User Says Thank You to scion fr-s For This Useful Post: | BrahmaBull1990 (05-06-2021) |
#49 |
Drives: 2014 BRZ
This reminds me: I put Redline MT-90 in my '14 about four years ago.
It initially had a bit of grind when going into second cold but was fine warmed up. Now (after four years) it seems to be perfecto in all weather. It only took four years.
#50 | |
I just switched to it and so far I’m impressed. It’s available locally for $9/qt. It’s less notchy than before the swap and if I recall it’s the smoothest it’s ever been. |
#51 | |
Drives: 2017 PP BRZ
#52 |
Señor Member
Drives: '17 BRZ PP
Another vote for Redline. Changed to it from factory oil and it made the transmission feel buttery smooth. I stopped using their engine oil because it is so expensive and I prefer to change at least twice a year, but trans and diff oil is worth it.
#53 |
In reality just about anything is better than the OEM fluid.
#54 |
Drives: Toyota GT86 GTS
Looking at changing mine over to Redline in the new year, so would the following be correct:
Redline MT-90 75W90 GL4 for Gearbox and Redline 75W85 GL5 for Diff. Car is a 2014 GT86 Thanks in advance. |
#55 |
Purist
Drives: 2013 FRS - Hot Lava
GEARBOX (GL-4) 75w80
![]() DIFF (GL-5) 75w90 NON-LIMITED SLIP
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#56 |
Drives: Toyota 86 2017
Im seraching the best one in 75-85 for the diff , for the trans i will take motul but motul dont do 75w-85 , what guy use in 2017 + ?
| Tags |
| differential, fluids, maintenance, oil, transmission fluid |
| Changed Diff/MT Trans Fluid to Motul 300 and super low MPG | jfg5067 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 01-18-2016 10:24 AM |
| Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 12:52 PM |
| Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 09:02 AM |
| Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 10:04 PM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
