Old 02-17-2021, 03:59 PM   #18915
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Dear Diary,
Well due to weather delays my exhaust, headers, and tune are not coming till next week. So I am just refreshing Fedex-tracking like an insane person to see when my originally overnight delivery will show up (currently stuck in IN)
Good news is 86Speed located me a Corsa exhaust! The Fujitsubo exhaust I wanted would have taken till April/May to arrive. The Corsa is coming from PA and sent out today.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
ripper (02-17-2021)
Old 02-18-2021, 08:52 PM   #18916
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by randomthoughts View Post
This is the best I can do for now until I get it off the jack stands.
Here is a link to the build process.
https://www.ft86club.com/forums/show...81#post3406681
Beautiful! Really well done, looks OEM. A perfect mod for all the stache haters.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
randomthoughts (02-20-2021)
Old 02-21-2021, 11:14 AM   #18917
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
It is looking more and more like I won’t get my exhaust in time for my mechanic appointment, so I will just have them install the headers and I’ll do the catback myself.
Problem is, I do not have a decent/safe jack stand setup. Does anyone have a jack stand or a ramp they can recommend me to get under the car enough for things like oil changes and exhaust work?
Thank you!
Old 02-21-2021, 03:54 PM   #18918
Dzmitry
Dzmitry's Avatar
Thank you!
People will steer you towards good brand ones, and it is absolutely up to you in which route you take (safety is in fact, the most important in this case). I would say the simplest thing to do is look up jacks / jack stands on Amazon. They have plenty of options including the best kind.
Just from a 2 second look on Amazon, some examples of great cheap ones are below. I bought my stuff at Harbor Freight and have never had a problem. Many will say that's the cheap way to go, so if you don't like that, what I provided below may be better. Or you can spend 50-200 more bucks and get the best of the best.
Jack: Pro-Lift F-767
Jack stands: Pro-LifT T-6903D
BrahmaBull1990 (02-21-2021)
Old 02-21-2021, 04:42 PM   #18919
soundman98
ProCrastinationConsultant
soundman98's Avatar
Thank you!
do you have a harbor freight near you?
a lot of guy's really like quick jacks if cost isn't a big deal.
https://www.quickjack.com/
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
BrahmaBull1990 (02-21-2021), Busybee (03-17-2021)
Old 02-21-2021, 05:26 PM   #18920
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thank you, gentlemen. I ended up going to a rent-a-lift place today and installed my Tomei UEL headers and flashed the ECU with ecutek (Delicious) Hell yeah. I’ve never done more than an oil change or spark plugs, so I feel proud.
Problem is: there was no check engine light immediately after the header install; flashed the ECU in the parking lot. I drove it home and it felt amazing. It was a 25 minute drive and all good till I pulled up to my block and I threw a code P0507 - high idle rpm? I thought the tune was suppose to fix that stuff? Zero issues driving, so I cleared it, drove another 20 minutes and it’s still off.
Do I let delicious tuning know if it comes back on? Sorry, I know this should go on the tuning sub and I’ll throw it up there if it needs an in-depth response
EDIT: just started up to go to the store and the code came back. Bleh.
Old 02-22-2021, 12:57 AM   #18921
dpfarr
Drives: BRZ ts
Had no idea there is such a thing as rent a lift.
dpfarr is offline   Reply With Quote
The Following User Says Thank You to dpfarr For This Useful Post:
BrahmaBull1990 (02-22-2021)
Old 02-22-2021, 07:33 AM   #18922
Dzmitry
Dzmitry's Avatar
If you're with delicious, just continue to do revisions. Send them a log and they will revise as needed to fix any troubles. Don't stop until you're satisfied, that's part of the price.
Old 02-22-2021, 08:09 AM   #18923
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
https://stewsgarage.com/
It’s great!
Okay, thank you. I know they are a reputable shop, so I have faith. The only thing I can think of is that I told Delicious when they created the base tune that I was adding a catback exhaust too, but that hasn’t arrived yet because of the storms in the Midwest. So maybe that is the cause. But either way, it seems to be an easy to fix since it’s just a RPM expectation error (the car idles fine).
I’m watching fuel trims in the meantime to watch for leaks
Old 02-22-2021, 10:40 AM   #18924
Dzmitry
Dzmitry's Avatar
Exhaust should have pretty much no effect on that so I'm not sure what the deal is. Either way sounds like you should be ok, and they should certainly have that fixed.
Old 02-22-2021, 10:45 AM   #18925
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I thought maybe I had a leak somewhere by my long term fuel trim is spot on at 0 +/- 2%
Dzmitry (02-22-2021)
Old 02-22-2021, 07:19 PM   #18926
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Installed a whiteline KD925 diff mount kit. Haven't driven just yet.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
BrahmaBull1990 (02-22-2021), MJones_RB (03-09-2021)
Old 02-22-2021, 09:26 PM   #18927
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Emailed Delicious and they sent me an updated tune a couple hours later...no DTCs or CEL. Hell yeah
Dzmitry (02-23-2021)
Old 02-27-2021, 02:12 PM   #18928
dpfarr
Drives: BRZ ts
Called the dealership to get my diff and trans fluid changed before tracking next weekend. “Your vehicle only has 6000?? We don’t recommend that until 60,000.” Me: “I uhhhhhh, I properly drive my car?”
I didn’t want to say I take it to the track. Ended up getting on my friend’s lift and getting Red Line into it. So much crap on my diff drain magnet.
Bonus, he parked his new 718S under it.
