Old 02-20-2021, 08:42 AM   #1
bramturismo
Drives: 2012 Pearl White GT86
Unable to re-flash car to stock with any tuning file.
Hello everyone,
I am putting my car back to original state, but I am having some difficulties flashing my car back to its original mapping.
Over the years, I have flashed my car to the stage 1 and stage 2+ mappings with my OFT v2 tablet. Currently the car is still on an altered stage 2+ mapping. Someone from our local GT86 community sent me this mapping, and as far as I know it is a stage 2+ mapping with some altered values.
I am running the latest OFT software on both PC and the tablet itself.
When I attempt to flash my car, the OFT will read "ERROR: Cannot communicate with ECU, please try again." It is unable to flash any of the tuning files.
I have checked the connection, and the pins of the cable. The OFT does seem to read my car as its showing me for example the battery voltage. I have also tried to disconnect the battery for half an hour, but to no avail. Likewise I have also tried to do it while the battery was connected to a charger, to ensure it is fully charged.
I will attach a screenshot of all of my tuning files.
Do you guys have any idea what might be going on? And how much of an issue is it to run my car with this mapping while on the original header and exhaust parts?
Thanks in advance, I really hope I can fix this issue as I am afraid to run my car at all right now.
Greetings!
bramturismo is offline   Reply With Quote
Old 02-20-2021, 08:47 AM   #2
gt7877
Drives: turbo frs
Hi
First of all clear all dtc's even there is no mil light
After
Flash direct what ever u need
gt7877 is offline   Reply With Quote
Old 02-20-2021, 12:21 PM   #3
bramturismo
Originally Posted by gt7877 View Post
Hi
After
Thanks for responding!
Could you clarify what you mean by dtc? I do not know what that means.
Greetings,
Old 02-20-2021, 12:37 PM   #4
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Fault codes..Diagnostic trouble code`s.. And Malfunction indicator lamp
Old 02-20-2021, 08:00 PM   #5
steve99
Drives: FT86
See if oft will log data ie display ecu parameyers on the real time data screen
if it does then connection ok.
battery volts needs to be at least 12 to flash
make sure ignition full on ie all dash warnings lit up but engine stopoed when trying to flash car
Old 02-21-2021, 05:32 AM   #6
bramturismo
Is this the MAF voltage in the realtime logging screen?
When I press on ECU Fault Codes, it reads "No ECU fault codes found."
Old 02-21-2021, 04:47 PM   #7
steve99
Drives: FT86
does real time log screen log data ?
OFT: Cannot create a tuning file halujeddo Software Tuning 11 12-10-2017 03:19 PM
tuning file John27 Software Tuning 3 04-22-2017 01:23 PM
Unable to log with OFT FW v137; template file? FR-Slide Software Tuning 2 05-02-2016 08:26 AM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
Ecutek help: unable to choose rom file in Programming Tools software Fizz Software Tuning 7 12-18-2014 03:30 AM
