#15 |
I agree not good but he is leaking anyway. That was why i suggested true sealed first.
#16 |
LMGTFY
Drives: 13 FRS, 91 Miata
#17 |
Interesting, red and blue are listed as glass matt and the yellow is listed as AGM on their web . Wonder what the difference is.
#18 |
LMGTFY
AGM = Absorbent Glass Mat.
Don't think there is a difference. Whoever came up with what to put didn't use the same wording. |
#19 | |
Drives: 2013, Subaru BRZ
I checked what AGM batteries are available locally, and I think the Optima is my best bet since they have a warranty here of 2 years. They don't have the "Yellow Top D35" available til April but they do have the "Red Top 35" Batteries here don't often last more than 3 years because of the extremely hot weather. But I hope getting a new battery will fix this issue. Also are optima batteries still any good, I heard they stopped making them in the USA so the quality isn't as great as they used to be? How long should the Red Top last me? |
#20 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
| The Following User Says Thank You to RZNT4R For This Useful Post: | ka-t_240 (02-18-2021) |
#21 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | humfrz (02-18-2021) |
#22 |
I would try and wait for the yellow top. With a proper charger, you can bring the yellow top back from the dead
Search the Optima Batteries Facebook page for an article on charging/saving batteries. |
#23 |
Drives: Crapcan
You can also parallel it with another battery that is good and charge them together.
#24 |
Hi guys I did some more digging and I'm thinking about 2 different batteries leaking when I go on the track but not on the road.
I'm starting to consider the possibility of a faulty or failing "battery current sensor" the little sensor attached to your negative battery terminal. Since the problem doesn't come out while the car is being monitored, maybe it overcharges for an instant and the ECU doesn't notice it happening? idk i'm just trying to rule out some possibilities since i'm not detecting any overcharging when I have the battery/alternator checker clamped onto the battery. EDIT: I haven't gotten and tried another battery yet. I'm still in the process of cleaning and repainting the places where the battery leaked Last edited by Delmar; 02-20-2021 at 08:17 AM. Reason: Additional info |
#25 | |
Master Collaborator
So I have been watching this thread since you started it and reading through your previous posts and looking at the pictures, I see that you have the older style current sensor. The note in the picture notating the model year changes of the current sensor from 2016 to 2017 which is now a battery condition sensor, indicate that the charging system has been redesigned from three phase to single pole for efficiency purposes. Is it at all possible that your alternator is the redesigned part from 2017 and newer? Did you purchase your car brand new or did you purchase it used? Could it be that the prior owner installed the newer-style alternator instead of the correct one for your model year, which could be causing the problems that you're experiencing with the batteries leaking? |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | humfrz (02-20-2021) |
#26 | |
The alternator is still a 3 phase alternator. It's a lot more powerful than the 2016, but it's still a 3 phase alternator. The difference between the 2016 and 2017 is in the way the alternator is controlled, the 2016 alternator has a big 12V charging post and a connector with 3 wires: A turn on circuit, a charge lamp control circuit and a control circuit from the PCM for a square wave input, the duty cycle of which controls charging voltage. The 2017 alternator has just 2 wires going to it: A big 12V charge lead and a single control wire. It gets it's 12V and Ground internally and the single control wire is a LIN bus interface, it's not driven by a square wave from the PCM, but rather it regulates itself internally and receives charging requests as network packets and can output diagnostics to the PCM over that same wire. A 2017 alternator in a 2016 car would not work. The connector for the control wires doesn't fit in the socket, and even if it did, the 2016 PCM would be sending a square wave instead of network communication. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | humfrz (02-21-2021) |
#27 | |
Master Collaborator
Technically, I didn't misunderstand. I know that the charging circuits have had a redesign and since I only have my '15 FR-S to look at under the hood, not being able to compare it with the newer design, I was speculating if it is at all possible for the newer alternator (or even an aftermarket replacement alternator that may look identical on the outside to the OEM alternator, just not have the same internal electronics, i.e. made in China) to be installed in place of the older OEM alternator, and could that be the source of the problem. But it looks like you've answered that question. If the OP isn't getting a CEL or has any DTC's in the ECM then yes, it's probably the correct matching alternator for his model year. We still need to find out if his charging system is still stock or not. Maybe at some point his alternator was replaced with a lower quality aftermarket unit that simply didn't have the tighter OEM tolerances. I've read a lot here about other members tracking their cars but this is the first time I've read about multiple brand new batteries leaking in one car. There could still be a current sensor intermittently going bad under extreme heat environments such as during track use that may be causing the problem, or again an intermittently faulty alternator internal component that breaks down under high heat. A constant voltage monitor and data logging during track use would reveal an intermittent overcharging situation. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | humfrz (02-21-2021) |
#28 | |
I've attached photos of my alternator (and the information sticker in the back) if that helps |
| Battery Leaking - 4th Replacement | djrbash | Issues | Warranty | Recalls / TSB | 23 | 02-14-2021 11:16 PM |
| Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 12:55 PM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 12:07 AM |
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 12:35 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
